Question about Home
I bought 3 urberhaus 4/6 L dual flush one piece high efficiency toilet HET 1.28 gpf item # L1315E346 PO # VC7023 1309 2811934 SKU#70235002. 2 are working fine except one which after flush, the water will keep on going for a long time but not filling up the tank. The water level is rising very very slow. It takes about 5 minutes to fill up the bowl while the other two only takes 1/2 minute. To fill up the bowl faster, I have to remove the small plastic pipe where the water was running out and let the water fill up the tank. Please advise how to fix this problem. Many thanks M. Wong
2 Suggested Answers
  • 35 Answers
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Posted on Dec 21, 2008
Kohler cimarron very noisy when flushed
You probably have one of the newer Cimarron-series toilets that feature what Kohler calls "AquaPiston" technology. These gadgets use the water pressure in your supply lines to pressurize a charge of flush water in the tank, causing the flush water to rush into the bowl at high pressure and velocity. Many Cimarron-series toilets use only 1.28 gpf (gallons per flush), compared to the current industry standard of 1.6 gpf for conventional gravity-flush units. Reducing the gpf rating by 20% requires pressurizing the water in the tank, and the release of pressurized water makes a lot of noise. I'm afraid your toilet will always be noisier than what you may be used to.
Sep 22, 2017 | Kohler Home
AquaSource High-Efficiency 1.6; 1.1-GPF (6.06; 4.16-LPF) White WaterSense Dual-Flush Elongated Chair Height 2-Piece Toilet from Lowes that won't evacuate the bowl during a flush.
The flapper may be closing before the tank is dumped completely. You can verify this by observing flushing action with the tank open.
Apr 13, 2017 | Maximum Home
Which toilet is best?
I replaced the 2nd floor toilet in my house several years ago. It has all the features you require, except the 17" tank width. If you can fit a 20" tank ( actually 19 3/4") then the brand to buy is Toto. The quality is unsurpassed.
The (included) *seat* height is 16 1/8". GPF is 1.6, but the flush is amazingly powerful. I opted for the special self cleaning coating they call "Sana Gloss". Nothing sticks to it, it doesn't stain, and I've never had to use a toilet brush nor bowl cleaner on it the whole time I've owned it.
I bought mine from an online distributor. Just Google "Toto". I haven't checked recently, but they may have a narrow tank model. Mine has the extended bowl.
Apr 15, 2014 | Home
Uberhaus dual flush toilet power-assisted
buy a simpler toilet less problems and you will sleep at night
Jul 18, 2013 | Home
I bought a house that has some older fixtures and all of the toliets (3) are the American Standard 13.2 / 3.5 GPF models. The one toilet in the main washroom flushes odd, in that when it flushes often a...
You probably have excessive buildup on the pipe walls that have restricted the flow to the point of needing that second flush - or somebody flushed a plastic bag there and now it is acting like a flapper. This will also be evidenced by occasional flooding at that commode. There's only 2 solutions as I se4e it.; scrape the pipe walls ( rooter with a scraping head ) or replace the pipe for the build up, or rooter out the pipe to try to extract that blasted bag.
Good luck!!
Nov 20, 2010 | American Standard Home
We bought a Kohler Cimarron complete solutions 2 pc. toilet about 2 months ago and now it doesn't want to flush properly.The toilet fills half way up with water instead of just wooshing down like it...
Before taking it out you need to go back to Lowe's and purchase a toilet auger....
With this you can crank it down through the trap of the toilet and remove the obstruction...there is something in there that a plunger will not remove...example...a pen or pencil... comb...these are commonly removed when I het the symptoms you are giving...
heatman101
Aug 13, 2010 | Kohler Cimarron Comfort Height elongated...
Handicapp Toilet Bowl does not fill - up as high as regular toilet > very small amount of water in bowl after flushing ie> about 10 cuos of water.. JUST INSTALLED IT NEW YESTERDAY...
Wiith all due respect, the Drake toilet is not a regular toilet and doesn't sound the same as a regular toilet when you flush it. It is in the design that allows it use only 1.5 gpf instead of 3.5 gpf. A rather unique thing is that while it is scientifically calibrated to release 1.5 gpf, it does not empty the tank of approximately 1 gallon of water. Therefore if one feels the need for a little extra umph, simply hold down the flush lever when you flush until the tank is emptied.
Aug 04, 2010 | Toto DRAKE ELONGATED HANDICAPPED TOILET...
Toto Dorian toilet does not flush clean
Don't know if you have calcium build up problems. If you do you could pour a calcium cleaner into the tank to try and clear up the problem. This would be the only way to possibly clean the enclosed area. Good Luck. Jeff
Apr 05, 2010 | Toto Promenade, 1.6 GPF, Elongated...
My flushometer toilet will not stop flushing. The
Try checking the water pressure. If it has dropped too low then the valve will never re-seat properly. Ideally over 90 psi.
Apr 02, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Home Logo
49 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
