Question about Hitachi Office Equipment & Supplies
Stylus pen not working - Hitachi Office Equipment & Supplies
Does the Wacom Intuos2 Classic Pen (xp 300e) work with the Wacom Bamboo CTL 470 tablet?
From what I read on Wacom's site, they are NOT compatible.
The Bamboo use a stylus that is different than the nib pens that the Intuos use. The stylus for the Bamboo is more like the stylus you can purchase for smart phones. The Intuos pens are pressure sensitive and have different nibs you can use for different effects and feel. You can go to their website and look for compatible pens and stylus' for your specific tablet.
Aug 02, 2014 | Wacom Intuos2 Classic Pen (XP-300E)...
What is the best stylus pen?
here's a list of the top stylus pens there are: http://graphicssoft.about.com/od/iphoneandipodtouchapps/tp/Stylus-Pens-Brushes.htm
Jan 20, 2013 | Computers & Internet
Wacom Stylus not working on my DTZ1200. It shows that the pen is being red by the tablet but doesnt show the target from the pen point or be able to select from any selection in photoshop. Its and old...
you may have installed the driver for windows xp or a later version then windows 7, you will have to make sure you install the correct driver for you OS
Aug 16, 2010 | Wacom Stylus Pen for Graphire4
My stylus suddenly stopped working. The eraser end works fine, but the nib end gets no response on the computer. Please help. Thanks.
you have to change the pen nib, it is quick and easy, and you can buy the nibs separate if you don't have any
Jul 02, 2009 | Wacom Stylus Pen for Graphire4
Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Apr 14, 2009 | Computers & Internet
Problems
The stylus pen works by pressure on the tip. Since the tc1100 uses an active digitizer, as soon as you come within range of the screen, the mouse should move (this is called pen-hover), however, if the tip is stuck upwards it will write or click instead just as if you were touching the screen.
Try carefully pulling out the tip using a needle nose pliers or your fingernails if they're strong, and then reinsert the tip gently. This should un-stick it. If this doesnt work, there may be an internal problem with the stylus.
Jul 26, 2008 | HP DG937A - HP Tablet PC TC1100 Tethered...
21 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
