Question about HP Compaq dv6135nr Refurbished Laptop - Intel Core 2 Duo T5500 1.66GHz, 802.11a/b/g Wireless, 2GB DD (RG364UA) PC Notebook
How to change hp pavilion dv6135nr bios battery change?
How do you know if you needa new battery?
The only battery there is in a desktop PC is the bios battery. If you mean that, then you know it's time to change it when you get 'bio setup error' messages when you turn on the machine.
Sep 29, 2013 | HP Hewlett Packard Pavilion Slimline...
How to fix bios setting on hp pavilion a6110n
The best way to reset the BIOS back to the defaults (if there isnt a setting to install the defaults), is to remove the BIOS battery for 15mins. This will drain the charge from the BIOS, insert the battery and then go to the BIOS setting to set the Date and Time.
Apr 11, 2012 | HP Pavilion a6110n PC Desktop
I forgot my password for my laptop hp pavilion zv6000
try pressing either delete or f2 during the boot process to enter the BIOS you can change youre password but be very carefull you can upset your computer in there change one setting at a time see if it works
Jul 23, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have an HP Pavilion ze4200. It will not even
1. It looks like a battery problem!
2. Plug in your laptop to fully recharge the battery!
3. After 3-6 hours, try to start your system!
4. You can also check by changing the power jack / socket!
5. Is the battery light On / blinking ?
Jan 04, 2010 | HP Pavilion ze4220 Notebook
I have a hp pavilion a635w that will not boot up not even to bios
check if the ram if is compatible with the board
check if the battary power the bios
Dec 22, 2009 | HP Pavilion A635W PC Desktop
Reset BIOS on HP Pavilion a750w
Fastest way to reset BIOS is to remove the CMOS battery (looks like a large watch battery on Motherboard) for 30 minutes. After you replace the battery, the BIOS should reset to default. If further problems arise involving the BIOS, it's possible the CMOS battery is bad.
Dec 13, 2009 | HP Pavilion a705w PC Desktop
Hp pavilion dv2000 Turnoff due to overheating
1) plz go to power options from control pannel and change the power options as never never
2) we can do one more thing,we can do a Bios update
everything tis going to fine
ITS Works
Dec 06, 2009 | HP Pavilion dv2000t Notebook
Friend gave me an old hp pavilion xz1185 laptop,but he dont recall password for cmos to get in,can i reset cmos?
This may not work but give it a try.
Remove the BIOS battery and the main battery from the laptop for 15+ minutes. Insert the batteries back into the laptop and the BIOS will return to the default setup, hopefully removing the BIOS password. You need to go into the BIOS configuration to set the Time and Date etc. again.
Nov 22, 2009 | HP Pavilion dv6000z Notebook
Bios locked and not get full display
you can reset the bios by taking out the battery on the motherboard (looks like a watch battery) leave it out for a few minutes then replace it again.
Have you tried changing the display.
Right click the desktop, go to properties or personalize if using vista, and check that the display properties is set correctly for your graphics card. Change the size of the display from in here.
I hopet this helps.
Nov 11, 2008 | HP Pavilion dv4000 Notebook
HP Compaq dv6135nr Refurbished Laptop - Intel Core 2 Duo T5500 1.66GHz, 802.11a/b/g Wireless, 2GB DD (RG364UA) PC Notebook Logo
14 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
