Question about HP Compaq Presario SR1500NX (PX786AA) PC Desktop
I need to know what kind of hdmi graphics card will work for a compaq presario sr1500NX
I need to install an hdmi graphics card so I can turn my v into a monitor but I dontt know what kind will work
    An expert who has answered 500 questions.
  • 620 Answers
Hello there
Well verify, a few things:
1) power supply
2) space
3) dimension of your ATX tower case
4) select a HDMI video card GE force 7 or above that came with HDMI specs.
you will be ok!
Posted on Jan 26, 2017
SOURCE: what graphic card do i need to watch movies from pc to tv
U can install nvidia graphics card
Posted on Jun 01, 2009
  • 20 Answers
SOURCE: what motherboards are compatible with a compaq presario sr1500nx?
I doubt you will find a non compaq mother board that fits the case.
It might be easier to get a new case and motherboard and then move all other parts to the new case.
I checked the specs online, the system was designed in 2005. The system RAM and CPU will limit you performance.
You might want to try or a similar type of supplier. They may be able to find a replacement that fits.
Posted on Jul 11, 2009
  • 1183 Answers
SOURCE: ATI AGP card and Compaq Presario S3100NX with open AGP Slot
This particular model of the system is basic home use system not built for games.
You can put in either a PCI graphics card or an AGP 4x graphics card that should not take more than 1.5v of power.
The max you can put is 128 MB , you can try the 256 MB, but i would suggest against it .
Thanks for using fIxya
Posted on Nov 08, 2009
Testimonial: "This is useful info about the memory capacity to work properly. Thank you so much!"
  • 161 Answers
SOURCE: sound problem
This is fairly common after installing new hardware or software.
There are several easy fixes, but the one that works best is to:
Uninstall your Sound devices, reboot, and your system will automatically reload them either from your System drivers or from the Internet/Microsoft.
There are many other simple ways, but this has the highest positive results and usually removes problems and reverts back to the working defaults.
Posted on Jan 16, 2010
  • 17 Answers
SOURCE: sr1720nx compaq presario no signal to monitor
Try changing the VGA cable or the other cable you are using.......
If that does not resolve your problem and that the monitor is good it means that your desktop's graphic card is damaged.....
Try replacing the graphic card or if it is an internal one..... add one in your agp or pcie slot
Regards :)
Posted on Jan 22, 2010
I figure I need a replacement graphics card. The PC worked fine yesterday. Turned it on today and no signal to monitor. Tried both DVI and HDMI with the same result. Monitor is Gateway LP2417.
try pulling the power cord out of the monitor and then wait 30 seconds and pull it back in to monitor . Are you dealing with a graphics card or a motherboard video chip. May have DVI and HDMI plugged into motherboard rather than PCI video card. Check Bios to see if conflict exists between motherboard video chip and PCI video card.
Dec 31, 2015 | Gateway GM5632E 2.4ghz Core 2 Quad 3GB Ram...
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Mar 26, 2015 | Lenovo ThinkCentre Computers & Internet
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector;
2) DVI;
3) HDMI;
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
Alba 22 Inch monitor drivers
You need to explain your actual problem. What operating system, graphics card, PC, resolution required, monitor model number, connector type being used (VGA, DVI, HDMI) etc.
Monitors don't usually require drivers to work. Drivers for your graphics card may affect operation or you may be using the wrong lead/connector/interface.
Sep 27, 2012 | Computers & Internet
I have an AOC L19WH LCD monitor. I am trying to get sound out of the monitors speakers but am having problems.
I can't find the model number you posted from the AOC website, so its hard to help you.
The only way you can get sound from a monitor is if you plug in the HDMI cable, this means that you need a graphics card with HDMI, very few computers have onboard HDMI.
Monitors that have speakers use HDMI and they need to be plugged into a HDMI port.
If you are using the DVI port, you will NOT get any sound.
You need to post the correct model number or a link to your manual, you also need to post what computer and what graphics card you have.
If you post this info, then someone can help.
The posts above are funny, a PSU has nothing to do with sound.
Apr 05, 2012 | Computers & Internet
I have sapphire ati radeon 5570 graphics card. i have aoc 912sw+ 19 inch lcd monitor. how to connect hdmi port of graphics card with monitor?
the HDMI port is for connecting video and sound to a home theatre / surround sound system. I understand that this monitor only has a VGA connector.
The sapphire ati radeon 5570 graphics card has the following ports on the back to connect to a display: DVI (white), VGA (blue) and DisplayPort (the thin slot in the middle). You can use an ordinary VGA cable to connect the card to your monitor.
Unfortunately you cannot connect this card directly to your monitor using the DisplayPort.
Hope this helps
Jul 21, 2011 | AOC 912SW-4 Monitor
After replacing HDD and installing Windows 7 computer appears to not recognize 42" plasma TV as monitor connected to HDMI port. Worked before HDD replacement.
You will likely need to reinstall your video drivers. You'll need to find the make and model of your video card and then go to the manufacturer's website to install the proper drivers.
Mar 25, 2011 | Acer Aspire X1200 Desktop PC - Athlon X2...
Graphics card hdmi output to monitor digital input seems to not be working
i am having a problem with my sound and i need sound driver for dell dimension 2350
May 22, 2009 | Gigabyte Computers & Internet
Compaq 510s sff. Graphics Card
Hi Mikey You need to go to your bios setting and change your graphic adaptor from PCI/.. to AGP 1- turn your computer off (Shut Down) 2- keep press and release "delete" key on your keyboard while turning your computer on untill you go to bios (normally blue screen) 3-find your desplay/graphic or anything that is related to graphic. 4- Change it to AGP Now it should work but if it didn't work: 1- Faulty Display (Monitor) 2- Not compatible graphic card(rearly) 3- loose or damaged cables 4- Damaged Motherboard please let me know of your progress Kind Regards
Oct 07, 2007 | Compaq EVO D5S SFF Refurbished Desktop...
HP Compaq Presario SR1500NX (PX786AA) PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
