Question about Samsung Televison & Video
How do I stop my flat screen from automatically changing the aspect ratio?
I have a new computer and am using my 47in Samsung LCD flat screen as the monitor. It is hooked up through a Bose V25 home theater set up via HDMI cables. The problem I am encountering is with the aspect ratio. The display cuts off all the edges. I manually turned changed the aspect ratio to 'Just Scan' and it fixed the issue, temporarily.In a seemingly random fashion, the aspect ratio will revert back to what it was originally with all the edges cut off. If I change sources, it will generally revert. Is there a way for me to lock it in for that particular source?
    Top Expert:
  • Samsung Master
  • 76,848 Answers
You can't.
Posted on Apr 26, 2017
SOURCE: Aspect Ratio not responding/always in "Full" mode
i have a panasonic th-42pwd8bk tv i have it working through my sky box, but it only works in black & white no colour. it works in colour on my pc what am i doing wrong. i have no user manual
Posted on Apr 22, 2007
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Posted on Nov 19, 2008
  • 458 Answers
SOURCE: edges of picture being cut off LG 37LG30 LCD TV
Yes, it is possible the settings from your cable box maybe set to the wrong ratio eg:letterbox. Depending on what type of box you have, look in the cable box menu for a settings option, then change the aspect ratio to a different format.
Posted on Jun 30, 2009
dave1645
  • 834 Answers
SOURCE: My N2635w 26 in. LCD Television is set to VGA, and won't change
you will need to temp hook up to w pc to get a signal into it then change it I hate that when that happens
Posted on Nov 30, 2009
SOURCE: Have my laptop connected to HDMI input on my
Download the latest ATI Catalyst software. Under Desktops
Posted on Sep 03, 2010
How do I stop the aspect ratio from auto changing on my flat screen set up as the monitor for my computer?
When you set it to just scan the source will determine the scan. I would remove the bose from the unit and connect the cable or sat box directly to the hdmi in of the tv. if the problem persists check Samsung web site for software upgrade. If upgrade does not fix replace the main circuit board.
May 07, 2014 | Samsung Televison & Video
Where do i set the aspect ratio for the samsung hdpv1080i?
go to menue under pic setting you should find a tv/ratio setting click on it to change ratio
Feb 24, 2013 | Samsung SP-M255W LCD Projector - HDTV -...
The television was purchased four years ago as a floor model and didn't come with a manual or remote, so we purchased a sony remote per the salesperson instructions. Unable to figure out how to change the...
Sorry aspect ratio or P.size it more of an original remote functions.Can't used a substitute remote for this functions.Try website like Remotes.com to buy an original remote.
Feb 07, 2011 | Samsung LNT5265FX 52 in. LCD Television
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Picture too big for screen. It's a Samsung 40'' LCD
What source are you using and which model of Samsung?
Chances are its the Aspect ratio on the source or the Aspect ratio on the TV. Failing that the Zoom setting. A few more details would help immensly.
Cheers,
Jan 06, 2010 | Televison & Video
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
The picture on my LCD 52" 650 series TV makes everyone look short
There is an aspect ratio setting in your menu options. You will have to change the aspect ratio so you get a normal screen.
This will most likely fix your problem.
If by slight chance it doesn't, you will have to remove the back of the tv and find the manuyal adjustments for it.
All newer Tv's have the aspect ratio/picture change setting.
Jan 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
Ilo tv
You need to change the aspect ratio of the screen. The cable box remote has an aspect ratio button and the tv remote also has an aspect ratio button or picture size button. You are probably on a zoom aspect since its too big.
Nov 13, 2008 | iLO 3200 32 in. LCD Television
Samsung LNT3242H
Try to change the aspect ratio of your tv to see which is better fit for you.
Jan 01, 2008 | Samsung LNT3242H Television
Televison & Video Logo
Henry  Thomas
Henry Thomas
