Question about Numark Industries Numark X6 Two Channel Professional Digital 10" Mixer
How can i fix a bad input on numark x6 dj mixer?
Channel 1 red input is weak and staticky, also headphones are poping with power on/off even though no inputs were connected. A/C adapter makes a humming when power is turned on to the mixer.
5 Suggested Answers
  • 5603 Answers
SOURCE: HISS from Numark DM1200 mixer.
All interconnected equipment MUST be powered from the same receptacle or source. The XLR to the speakers should NOT have ground lift. The power for the mixer should come from where the speakers are and be routed alongside the XLR cables. All the other connected items should also be powered by the same source. The ground bounce within a building cannot only cause noise, but can rupture the input circuits of equipment. As an electrical engineer I don't know why manuals supplied with the equipment doesn't go into this more. The professionals at the big venues all know this as they have had to pay to get equipment repaired.
Now to get down to "hiss" once you get the other stuff straightened out, there are two things to know at the start: The first is that due to the statistical nature in electronics "noise and hiss" are among the laws of physics that we can't completely get around. The level of the hiss should NOT be objectionable however. The second thing is that proper level setup is important to minimize the effects of noise and hiss. You should be sending the levels to the powered speakers at near full line level into the line inouts, never mic inputs that some have. Using excess gain at the speakers will amplify any noise pickup on your audio lines. Next, at the mixer, try to keep all the level controls around 10 to 2 0'clock for rotaries and 70% for faders. Excess gain at certain stages will cause hiss to be objectionable.
Posted on Mar 19, 2011
domotek
  • 591 Answers
SOURCE: I bought a second hand
The headphone connector is probably defective... loose connection...
Posted on Apr 10, 2011
djredskyy
  • 670 Answers
SOURCE: I just bought a new
in your system preferences click on sound and adjust the settings you need.
Posted on May 09, 2011
sg1972
  • 225 Answers
SOURCE: I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Posted on Nov 01, 2012
I NHAVE A TERRIBLE HISSING SOUND ON MIC IMPUT 1
With a mic plugged in, or with the input open? With the channel volume up or not?
Jul 01, 2016 | Numark Industries Numark KMX02 Dual Deck...
Hum in speakers using numark c3fx
Or an earth problem (connecting cable problem) or dirth in potentiometers or some leaking or bad capacitors
Feb 08, 2014 | Numark Industries NUMARK C3FX DJ MIXER
Sound quility is poor on phono side vol., E.Q, channel control are'nt responding properly sound like the sound is up to high
I think that something is wrong. The phono connectors are exclusively for vinyl turntables with phono cartridges. In case you connect a cd player or other compatible source at these connectors the sound is highly destorted and the result is terrible. Could you please clarify me what audio device do you use at the phono input.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 02, 2011 | Numark Industries NUMARK M2 DJ-MIXER
I just purchased the behringer djx 700, and the channel 2,3,4 are all distorted when i play music. Even when i listen to it through headphones you can still hear the heavy distortion. What can i do to...
You are probably overdriving the inputs. You haven't told us the source of the inputs and we can't guess where they may come from. You need to read the manual and make sure your source outputs are within range of what this unit requires.
Jul 17, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
My DJM 400 one of the outputs is louder and has distorted sound what do I do?
First verify that one channel is bad by swapping the output leads and seeing the bad audio comes from the other speaker. Assuming it does, you probably have a bad output driver on one side.
This can happen if one powers part of the system from different receptacles in a venue and electrical disturbances destroy one or more audio interconnects. ALWAYS power ALL interconnected equipment from the same source, even if you have to run an extension cord between power amps and the mixer.
You will probably need to take the unit for repair. The parts cost should be nominal, however labor could cost a bit.
Find out is SAME distortion is present in the headphone output. The circuitry shows a bunch of muting transistors and one of them could be bad... but we can do some troubleshooting externally with testing at headphone jack, etc.
Oct 14, 2010 | Pioneer DJm 400 Professional DJ Mixer
I have a numark cd mixer and one of the cds wont play can you help me find a place i can take it to fix
Where are you located? Also, is the mixer the problem or is it the actual player that is not working?
Thanks,
Dan
Aug 16, 2009 | Numark DM1200 DJ Mixer
Numark dxm power failure?
i'm having the same problem, just wondeered if you found any solutions to this?
Jul 14, 2009 | Numark DM1200 DJ Mixer
Numark Industries Numark X6 Two Channel Professional Digital 10" Mixer Logo
16 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
