Question about Samsung Televison & Video
How do I stop the aspect ratio from auto changing on my flat screen set up as the monitor for my computer?
I have a new computer and am using my 47in Samsung LCD flat screen as the monitor. It is hooked up through a Bose V25 home theater set up via HDMI cables. The problem I am encountering is with the aspect ratio. The display cuts off all the edges. I manually turned changed the aspect ratio to 'Just Scan' and it fixed the issue, temporarily.In a seemingly random fashion, the aspect ratio will revert back to what it was originally with all the edges cut off. If I change sources, it will generally revert. Is there a way for me to lock it in for that particular source?
    New Friend:
    Problem Solver:
  • 6 Answers
When you set it to just scan the source will determine the scan. I would remove the bose from the unit and connect the cable or sat box directly to the hdmi in of the tv. if the problem persists check Samsung web site for software upgrade. If upgrade does not fix replace the main circuit board.
Posted on May 07, 2014
SOURCE: Aspect Ratio not responding/always in "Full" mode
i have a panasonic th-42pwd8bk tv i have it working through my sky box, but it only works in black & white no colour. it works in colour on my pc what am i doing wrong. i have no user manual
Posted on Apr 22, 2007
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Posted on Nov 19, 2008
  • 458 Answers
SOURCE: edges of picture being cut off LG 37LG30 LCD TV
Yes, it is possible the settings from your cable box maybe set to the wrong ratio eg:letterbox. Depending on what type of box you have, look in the cable box menu for a settings option, then change the aspect ratio to a different format.
Posted on Jun 30, 2009
SOURCE: Have my laptop connected to HDMI input on my
Download the latest ATI Catalyst software. Under Desktops
Posted on Sep 03, 2010
  • 1212 Answers
SOURCE: I have the samsung LN52A550. When I turn the tv on a blue screen appears. I tried changing the source with the menu button but does not display anything. The TV is about 2 years old. The sound works.
Try this
Method one- with set on, hold down the exit button on the remote for 10 seconds. It will bring up the warning it will reset to the defaults it had when removed from the box and powered up initially. in the warning box it will show the cancel button highlighted initially. press the left arrow to select the reset option. You may end up doing this blind, so you may need to try it a couple times and the only indication of where you are is just a slight flash from part of the screen.
Once that left arrow has been pressed once, the reset option choice changes to "Ok" or "reset", press "enter" The set should
do it's thing to reset and then shutdown.,
Method 2
it should get you into the hotel settings, but you can reset to factory defaults from there, changing any other settings may limit access to the normal settings.
Shut the set off.
The while holding the mute, menu and info buttons, trun the set on while holding them down. If the functions portion of the board is working, it should bring up hotel options menu.
Posted on Feb 07, 2012
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
I have a 50" Plasma
Hi, the aspect ratio is set incorrectly for the source material or the screen is simply set to 4:3 aspect (old TV size) manually. There will be a menu function or an aspect button on the remote for doing this. Set it to auto which is usually good enough for most viewing though the ratio may change during adverts and back again for the film on tv watching. This can be annoying so when on tv mode observe the ratio set when the film is on and manually set this ratio, usually 16:9. The display will normally tell you the ratio setting at the point of change so you can do this. I hope this helps.
Steve at Olive Country Computers in Spain
Feb 19, 2011 | LG 50PX5D 50 in. Plasma HDTV
Syncmaster 152v repeatedly pops auto adjustment window
HI,
If you've changed the monitor recently, have you checked to make sure the Sync rate is not to high for the montior?
Steve
Nov 28, 2010 | Samsung SyncMaster 152 B 15" LCD Monitor
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
NEW WIDESCREEN TOOOOOO WIDE
Use menu button on monitor.
select menu.
select image setting
select aspect ratio
change aspect ratio to "Fit"
Jun 21, 2009 | Hannspree HW191D LCD Monitor
22'' LCD monitor aspect ratio is off.
Set resolution to the native 1680 x 1050. Then, using the buttons on the monitor, go into the monitor's menu. go down to "Image Setting", go to "HDMI Mode", then select "PC Mode". This should help everything fit on screen correctly.
Mar 17, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Aspect ratio
display setting
from the desk top right click and select properties, then select the settings tab then change your screen resolution display setting
Sep 16, 2007 | Acer AL2016W 20" LCD Monitor
Televison & Video Logo
67 people viewed this question
Henry  Thomas
Henry Thomas
