Question about HP PhotoSmart Office Equipment & Supplies
Keeps saying pint cancelled
Keeps saying print cancelled
can you please tell me which model printer you have...??
May 07, 2014 | HP PhotoSmart Office Equipment & Supplies
My Status light is blinking, red orange, green and It won't stop
This just happened to me! I found this fixya and it didn't help me. So I checked the status of the printer and it was trying to print some 3,000 envelopes, OOPS!!! Needless to say I cancelled the job but it still had to go through all of the pages before cancelling and finally stopped blinking!
Jul 18, 2012 | Brother HL-5370DW Duplex Wireless Laser...
My printer will not print. When you check the status of the document it says printing. When you cancel that it doesn't cancel. DAYS later the document prints all by itself. What's that about?
It's because the print queue is saved on the printer's flash memory. This happens when you don't cancel the queues properly or terminated improperly. To get rid of the issue, always try to give the command slowly and don't over load. If you are printing photos, try to make the file size small so that it'll not take long to spool and prepare for printing.
When the problem occurs, so as follows:
Cancel the queues from the print status box ("Cancel all documents"), if they are not cancelled, then turn off the printer (directly unplug the power cord from the printer), it you still see the printing status, keep on cancelling until everything's gone.
If the problem persists, restart your computer. Definitely the problem will be fixed.
It's also important to press the cancel button while the printer powers On.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | HP Officejet 5510 All-In-One Thermal...
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
My computer keep saying my 9650 printer is out of paper but it isn't
Try this:
Connect your printer and power it on. In the flag just cancel it. If it does help, go to printer and faxes, select the printer, then cancel all printing job wait for a moment until it disappear.
If nothing happens for sometime. Feed some paper to it, say 1 piece of paper, reactivate printing job, if print then no follow up paper it will flag again out of paper. Select cancel.
If it still doesn't work switch off and on the printer and repeat the process again.
Hope it helps you
Apr 09, 2009 | HP DeskJet 9650 InkJet Printer
Printer is pending
the print spooler is not letting it print cancel the pending jobs you will be able to print fine keep on cancelling the documents unless the icon shows 0 document pending ....
Dec 16, 2008 | HP Deskjet D2430 Printer
HP Deskjet 940c keeps saying it's out of paper, won't print
I have the same problem. In the error message box is a Cancel button.
If I don't click the Cancel then the print goes through just fine and I click Cancel when the print is finished.
Sep 28, 2008 | HP DeskJet 940c InkJet Printer
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Sep 01, 2007 | Brother MFC-7220 All-In-One Laser Printer
11 people viewed this question
Seeker5211
Seeker5211
