Question about Konica Minolta Office Equipment & Supplies
Paper empty Error still coming up even after load with paper.
  • Konica Minolta Master
  • 6,161 Answers
What model #################
Posted on Dec 30, 2015
4 Suggested Answers
SOURCE: HP Officejet 7410 AIO keeps saying out of paper when plenty of paper loaded
I have the same unit. There are many issues with it. First when you install the software you may need to add something to the registry.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Print\Printers\HP Officejet 7400 series\PrinterDriverData and create Key HPDJEnableSecondTray as DWORD with Value of 1
Once you've done this here is the biggest issue and one I've found to fix this issue PERIOD.
You need to go to your Printer Driver then to Properties of it then Device Settings Tab - you will see Form to Tray Assignment in the list and like 5 options, you have to make all but the one you want to NOT AVAILABLE. Example mine is set to Upper than Lower (Letter) all the rest are set to NOT AVAILABLE. Problem solved.
Posted on Apr 15, 2009
  • 41 Answers
SOURCE: paper loading error
hi the sloution to the problem is that to go ahead and try to reset the printer and it will definetly work ,
if you get stuck on some problem try to get in touch with me on fixya
Posted on Jul 22, 2009
  • 685 Answers
SOURCE: hp photosmart all-in-one "load paper"
Try this...
Posted on Aug 18, 2009
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
My fi-5220C says No paper on ADF paper chute or Hopper. (Code: Ds32003)
"No papers on the Chute unit" error occurs when the Hopper empty sensor detects no paper loaded on the Chute unit at the receipt of a Feed command.To recover this, Load documents on the Chute unit.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Is there a slip of paper left near Hopper empty sensor? Open the ADF and check inside visually.
3. Check the performance of Hopper empty sensor. Conduct Maintenance mode to see if the sensor works properly.
If the error still occurs, confirm that the cable is correctly connected then replace the sensor EM.
Thanks & regards,
ScanCare
Oct 02, 2013 | Fujitsu Office Equipment & Supplies
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Error oki b6100 e2
This error often comes when there an paper jam or paper tray 1 or paper tray 2 or 3 is empty,make sure that you have enough paper in the trays and secondly make sure that you have there is no paper jam in paper roller, even an tiny particle of paper can cause this error.
Please open all the access of your printer pull out all the paper trays and clean it properly with air blower, this can fix this error.
Sep 02, 2011 | OKI C5400 Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
Paper loading error
Jul 22, 2009 | Epson Stylus Pro 9800 InkJet Printer
Sd error on my top load kenmore oasis
Unplug the washer for 6-8 hours. We were told to try this by a local repair man before bringing the washer in and it worked for us. He said it would reset the washer.
Jul 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
HP LaserJet 2430dtn - "Tray 2 open or empty"
1-Is the paper set correctly in the tray? if you have Letter paper in it make sure the guides are snug against it
2-Check the lever inside the tray, remove the tray and look at the tires there should be a lever that you ca move freely that is the paper sensor
Oct 10, 2008 | HP LaserJet 2430dtn Printer
Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Sep 11, 2008 | Brother IntelliFAX 4100 Laser Fax
15 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
