Question about Philips 47PFL3603D LCD TV
Philips 47PFL3603D LCD TV - how do I change source input
How do I change the source input without a remote control on my Philips 47PFL3603D LCD TV
proton77
  • 1183 Answers
SOURCE: need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Posted on Jan 03, 2009
SOURCE: what is the remote control code for philips 42pfl3603d lcd tv
Hi - I had the same question and found it here:
www.universalremote.com/resources/pdfs/UR2-CBL-CV04.pdf
Some TV brands have multiple codes associated to it. You must try each one individually until one of them does the job.
This worked for me beautifully on a brand spanking new Philips 42'' LCD.
Posted on Jan 13, 2009
  • 53 Answers
SOURCE: Philips 47PFL3603D LCD TV - TV not responding to remote
One thing you can do is take your cellphone's camera, point the remote at the camera, and press a button. You should be able to see the infrared sensor firing.
If you can verify that, your remote's fine.
In this case, what you have is a bad IR sensor board. The part # is:
313926859182. Right now, there are so many of these things failing, that finding the original might be difficult.
Don't fear, though; it's a small part. And, best of all, it's cheap. Expect to pay around $5.00 for the part, maybe a bit more, maybe less, depending on the supplier.
Now, if you are handy with a power drill (fitted with an octagon/star bit for the back of your set), you can remove the 20 or so star-bit screws from the back of your television. Don't worry about putting the set on the floor. If your TV is on a stand, simply turn it around. You'll need to remove the stand screws, but you won't need to take the TV off of the stand.
Now that you've taken the screws out and removed the back cover, look in the lower left hand area of your set. You'll see a 4 inch long circuit board with 2 cables running to it. Pull the cables out (they'll come out easy). Remove the 2 star-bit screws.
One of the board's sides is under a plastic tab. Lift the board out of its slot from the other side.
Put your new board in, reconnect the two cables, reassemble the back and you are set to go.
Expensive repair for a few bucks and a better IR sensor.
This advice assumes that the control buttons (power, volume, channel) located on the side of the set still function. It also assumes you are able to use those buttons to power on the set and verify that you still have a picture on the screen.
Posted on Aug 02, 2009
  • 3 Answers
SOURCE: I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Posted on Mar 28, 2010
welcomejee
  • 10594 Answers
There could be many reasons like IR pins not soldered properly, it is not getting +B supply or IR output signal is blocked, buffer transistor on same board is bad etc etc
Replacement IR Board is available for $6 at Encompass.com so I would suggest to replace complete board instead of IR Sensor.
Hope these info will help you.
Thanks.
Posted on Jan 05, 2011
Setup TV without remote
here i have added the link to it manual. download the manual. Hope it will help to solve your problem.
www.electro-medical.blogspot.com
http://tv.manualsonline.com/manuals/mfg/philips/32pf7421d37.html
Oct 30, 2015 | Philips 32PF7421D 32 in. LCD HDTV
How do I change the source on philips tv without the remote?
You should have its remote control to select the inputs.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Gopakumar Gopalan Google
Aug 04, 2014 | Philips Televison & Video
Mar 27, 2010 | Philips 32PF5531D 32 in. LCD Television
I can't get my philips 47pfl3603d/f7 to work with a coby dvd968 home theater system the tv has one spdif coaxial out and coby also has one i pluged the cable, still can't get to hear my tv channels thru...
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Jul 26, 2009 | Philips 47PFL3603D LCD TV
Watching tv sound goes static
Hi there, this is a tuner issue. it can be repaired or replaced.
Feb 20, 2009 | Philips 47PFL3603D LCD TV
Need code for comcast remote control
HI,
Thanks
Proton
Jan 03, 2009 | Philips 47PFL7403D 47 in. LCD TV
Unable to select channels using the unit
First, test to make sure the Philips remote is working by trying to play a dvd. If the remote control is working, then either A) your TV is set to the wrong channel, or B) you have not selected the correct source on the Philips remote.
Look at how the cables run from the back of the Philips to the TV. In the back of your TV, the slot that the cables are plugged in to is usually labelled "AV1, "AV2, "Video 1", "Input 1" or something like that. Change the television to the appropriate input/source channel.
Press the Source button on the Philips remote and make sure it says E1 or whatever the appropriate source is.
Then try changing channels using the Philips remote.
This does not exhaust every possibility, but you must check the above first to see if anything else might be wrong. If the above does not work, then I would double-check to make sure the cable/satellite box is connected to the Philips correctly.
-Tha Mp3 Doctor
Dec 25, 2008 | Philips DVDR3576H DVD Recorder
Philips/Magnavox 32MF605W/17 32" LCD Wide Screen HDTV ready w/ATSC.
Yes you can. This TV has both VGA-In and component in support. The only thing you need to change is the input you're using with your remote control. As easy as changing the channel!
Oct 15, 2007 | Philips Computers & Internet
Philips 47PFL3603D LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
