Question about Akai Ewi4000s Electronic Wind Instrument
How to fix my noisy ewi? - Akai Ewi4000s Electronic Wind Instrument
Ewi 4000s cutting off
My EWI 4000s started to play by its self making a loud low note and then it stop and now it won't play at all. I Reset to Factory Preset but that didn't help. What do I need to do to get it to play again?
Feb 09, 2014 | Akai Ewi4000s Electronic Wind Instrument
Ewi and vocoder setup
hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder?
Mike Phillips is the same, or if it only works with the EWI 4000s?
and as a connection is made?
thank you!
Feb 04, 2013 | Akai Ewi4000s Electronic Wind Instrument
My Ewi is playing most of the patches in Bb and some in others keys. How can I fix it? I 've reseted and nothing changes
You may need to do a factory reset. It sounds linke a transpose setting has been invoked. Read your manual under the word "transpose". A factory reset, if required, usually involves holding one or more buttons or keys down while turning on power and holding them until the reset is acknowledged.
Jul 20, 2012 | Akai Ewi4000s Electronic Wind Instrument
Hi, I am writing from Holland. I need Akai EWI
Here is one link:http://www.patchmanmusic.com/ Although they do not ship hardware outside the U.S. there is lots of good info. This is a good store and they ship Internationally:http://www.sweetwater.com/c966--Wind_Controllers Contact them to see if they have the cable in stock.
Nov 22, 2010 | Akai Ewi4000s Electronic Wind Instrument
Reset. EWI4000s
Try this out
Turn off the EWI,
Press the LEVEL, FX, SETUP and TRANS buttons.
Then turn on the EWI.
This is a Factory reset.
I hope for You this is the solution.
Nov 13, 2010 | Akai Ewi4000s Electronic Wind Instrument
Robert Penny robertdrum55@gmail.com Where can i buy Akai EWI4000s and EWI-USB in Australia
This is the site:http://www.elfa.com.au/products/product+details?pid=71959 Electric Factory I88 Plenty Road Preston, Victoria, Australia Tel: (613) 947-41000 www.elfa.com.au List price for the EWI usb was$999.00. If this helped please rate me.
Apr 15, 2010 | Akai Ewi4000s Electronic Wind Instrument
How could I set up quarter tone in a precise way, that I could control with bend control of EWI?
Here is a good forum to join:http://www.patchmanmusic.com/forum/ Depending on what you are using for a sound module, I would recommend setting the pitch bend limit or range on the sound module to what you want and controlling that setting with whatever setting you have on the EWI. Read your manuals carefully and you should be able to do it.
Mar 02, 2010 | Akai Ewi4000s Electronic Wind Instrument
My akai ewi 4000s kind of froze
Please try to reset the ewi. You can do this like this: Shut down ewi. Press down the four little white buttons Level, FX, Setup and Trans. Keep them pressed while starting up the ewi.
This is a factory reset.
I hope this works for you.
Apr 03, 2009 | Akai Ewi4000s Electronic Wind Instrument
EWI4000s only plays one note
Hello a_marechalro,
You can try to reset your instrument.
Turn off the EWI,
Kind regards,
Fred Roubos.
Dec 26, 2008 | Akai Ewi4000s Electronic Wind Instrument
EWI won't respond to comands
I've got the solution.
Turn the EWI off.
Press the LEVEL, FX, SETUP and TRANS buttons all together.
Turn on the EWI.
This is a Reset to Factory Preset.
Greetings Fred Roubos.
Dec 13, 2008 | Akai Ewi4000s Electronic Wind Instrument
Akai Ewi4000s Electronic Wind Instrument Logo
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
