Question about Kenmore Washing Machines
110-82427830 won't spin
Machine started making noise and quit spinning .
  • 958 Answers
SOURCE: washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Posted on Feb 12, 2008
  • 6 Answers
SOURCE: Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Posted on Feb 13, 2008
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
IrishDruid
  • 2712 Answers
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
SOURCE: Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Posted on Feb 13, 2009
Washing machine wont spin
if its belt driven the belt could have come off or snapped hope this helps. if possible state machine make and model then someone should be able to help you more
Oct 09, 2016 | Washing Machines
Why is my washing machine making a noise when spinning the clothes?
you may have to remove the agitator to check for something like a bra wire , coins, bobby pins etc that is stuck in the tub holes and rubbing on the stationary tub when spinning
Sep 28, 2016 | Washing Machines
Why doesn't it spin?
sounds like a transmission problem. if it is a belt driven machine the belt could be worn or glazed andneeds replacing
Feb 06, 2016 | Washing Machines
Final spin won't go through... makes a squiky noise and no high speed spin
first how old is your machine. second is it under warranty? third have you tried to spin in all selections to see if your timer is working?
Dec 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
Spin cycle doesn't spin clothes dry. machine makes noise when it first starts to agitate but then the noise quits.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 28, 2011 | Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Making noise when spinning
HI there.This sounds like the centre bearing & seal are worn causing noise & water leak.It's normally called a Hub & Seal Kit.It is quite an involved job & without the right tools it would probably cost somewhere around $300 upwards to have repaired.Very good quality machine & worth while repairing.Try to avoid useing the machine until repaired as you could cause electrical short due to water leaking.
May 28, 2010 | Speed Queen AWS44NW Top Load Washer
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
