Question about Pride Mobility Products Go Go Ultra X 3 Wheel
Why is it when my Pride Mobil, Go-Go Ultra!!! is turned on and the forward handle is press it will stope and go, go and stop.
  • 175 Answers
Sounds like your speed pot is malfunctioning. This is part of the electronincs on top of the tiller inside the protective shroud. They aren't too expensive but you'll need to get ahold of a dealer or call Pride and they will refer one to you.
Posted on Aug 28, 2009
I have a pride go go ultra x scooter... I purchased it, and it had no top dash at all... I put a new throttle pot, and a whole new dash assembly... It runs great... Then I turn the speed pot to fast......
7 flash code is: Throttle control fault.
1. Check wiring for open/short circuits.
2. Check the throttle set-up.... The ohms should be very close to each other when placed checking forward and reverse on set up.
Aug 24, 2014 | Pride Mobility Products GoGo Ultra X...
Richard. when i push the power on the power lights flash and go out.Then the speed lights flsh 4 times then turns off
It is in the lock positions to unlock mash the on/off button for one section as soon as it beeps push the toggle switch all the way forward till it beeps then pull it back till it beeps then let go ,it will return to newtral by itself.you should be able ot operate it now .
Sep 13, 2012 | Pride Mobility Products New Pride Mobility...
Light rolling from green to red
stephen I think you are in sleep or lock out mode. Try turning the power on and pressing the horn button twice see if it stops scrolling if it doesn't turn the power off then turn it on and immediately push the joystick forward until you hear a beep then immediately opush it to the rear until you hear another beep then release it to the center. If it is in lockout you should see it return to normal lights Hope this helps
Nov 14, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Go Go Scooter travels in reverse, but when going forward it comes to an abrupt stop every few seconds. Everything else appears to work normally. Any ideas?
csr4 Well it could be the throttle pot or the speed control pot My leanings is toward the throttle pot since it works in reverse with the speed pot not being changed but not forward. when you are just changing the position of the throttle to forward thereby changing the pot wiper and getting the error. Contact Pride about the problem at 1-800-800-8586 and ask for Tech support for scooters and explain your problem to them. I hope this helps
Oct 02, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
How do i remove the chair. I want to change the batteries
Bob First unplug both connectors from the rear of the chair. Then on the right hand side under the seat push the small handle forward until it stops, then rotate the seat and pull up at the same time the seat should lift off the seat post. Carefully place the seat on the floor next to the base. Remove the shroud pulling upward to release the velcor fastners and voila!! the batteries. Now if the seat is hard to pull up try twisting it back and forth to help get it loose from the seat post. You might need some help in lifting because this seat and attached parts are heavy. After replacing the batteries grease the post to help getting it off easier next time. Hope this helps you
Sep 29, 2010 | Pride Mobility Products New Pride Mobility...
My scooter when I press the throttle to go forward it like breaks or stops. I have a Legend XL. It goes OK in reverse but, when you press to go forward it breaks like bad gas.
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Mar 02, 2010 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
Stop and go
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… info@mymobility.co.nz
Jun 18, 2009 | Pride Mobility Products Go Go Ultra X 3...
Pride jet3 makes noise when engaging forward motion
Sounds like your motors are gong out. You`ll need to get to a reputable dealer for further diagnosis.
Mar 28, 2009 | Pride Mobility Products New Pride Mobility...
Pride Mobility Products Go Go Ultra X 3 Wheel Logo
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
