Question about Craftsman Saws
My new craftsman garage door opener only travels 12 inches and quits
SOURCE: Craftsman Garage Opener /
door will not go down unless you hold down the inside botton.
Posted on Oct 14, 2008
  • 244 Answers
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
  • 118 Answers
SOURCE: Garage door opener chain out of sync with door
There are two white screws on the sides that adjust the limits. Adjust the "down" screw less. You should have to turn the screw 4 full turns for eight inches. After you make this adjustment, test it without the door being hooked up to prevent damage to the door or opener if it tries to close too far.
Posted on Mar 01, 2009
glenmann62
  • 91 Answers
SOURCE: Chamberlain garage door opener unit-is it compatible with craftsman keypad?
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
Posted on Mar 04, 2009
  • 3197 Answers
SOURCE: Garage door jumps when opened.
Release the opener from the door and operate the door manually. You can also operate the opener and this should give you a good idea where the problem lies. I think you have a door problem.
Posted on May 08, 2009
Hello, I replaced a worn out garage door motor with a new craftsman model. The door try's to travel down when the opener is pushed, even though the door is fully closed. I'm no garage door expert, but...
Yes, reread the directions travel needs to be set for both up and down, and MUCH MORE IMPORTANTLY the safety settings must be set. This allows the door to close on a foot and not cause damage....VERY IMPORTANT to set correctly....
Apr 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door stalls
The mechanical bearings and gears need some lubricants to smoothen the rotation. Try to apply some on the roller paths and joints
Aug 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
My garage door will only open about 12 inches and then stops. I have stanley electric door with a craftsman 1/2 electric starter
Check the door springs. Sounds like one could be broken. You might also remove the cover to the opener and check the drive gear. It could be stripped.
Nov 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
My opener will work if I hold the wall button down
Sounds like your door sensors are out of alignment or have gone bad. They each have a small light that should be on and not flickering for them to work properly. Tweak them a bit to get them aligned and check. If you can't get both lights to come on you either have bad wiring to them or a sensor that has gone bad.
Nov 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
The door doesn't move up high enough from the top of the garage opening, I have adjusted to chain nothing seem to work.
The 'up limit' control is on the side of the motor unit. Turn it in the direction of the arrow printed on the cover. Each full turns is approximately 2 inches of trolley travel.
Nov 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener won't close completely
look on the side of the openeer usually lekt looking at it from the rear theese are your travel adjusters one turn = 2" travel normally
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door
sensor got bumped, realign till both lights show green
Mar 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Saws Logo
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
