Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Why is my frigidaire front door display flashing the temp and flashing i hr duration. whats that mean?
It still cold but how do I get the front display from flashing?
3 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: My upright frigidaire freezer is set on -1 degrees, but the display on the front indicates the temp is 8 degrees. It has gone as high as 11 degrees. Does this mean it is defrosting or is there anoth
    Hello swanee3669 - Have you trying measuring the temperature inside the unit to confirmed that it matches the display? If so, I recommend contacting a professional to accurately diagnose the unit since it sounds like it could possibly have a bad sealed, thermostat or control board.
    Posted on Sep 27, 2012
    chrispolkele
    • 4342 Answers
      Verified Fixya Pro
      SOURCE: my new frigidaire freezer the digital display on outside of door flashes off what to do?
      Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
      Posted on Nov 05, 2012
      Fridgeaire upright freezer no serial numbers to be found anywhere was trying to adjust temp on front of door outside now unit says of and is not running how to turn back on???
      tough one
      i guess its a frost free
      turn the thermostat adjustment to on /highest temp temp ...then off /lowest
      till the compressor kicks in
      if not suspect faulty digital display panel or thermostat itself
      agreed no serial number etc
      makes it very hard to help you fix this
      http://kitchen.manualsonline.com/manuals/mfg/frigidaire/frigidaire_freezer_product_list.html
      Oct 11, 2016 | Frigidaire Freezers
      Lffh21f7hwa
      Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
      Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
      My new frigidaire freezer the digital display on outside of door flashes off what to do?
      Nov 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
      My upright frigidaire freezer is set on -1 degrees, but the display on the front indicates the temp is 8 degrees. It has gone as high as 11 degrees. Does this mean it is defrosting or is there another...
      Sep 25, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
      My Frigidaire freezer (not frost free)won't stay cold
      look at level side to side , and front to back. if not level door can leak . you will see water where it is leaking. check defroster is if staying on .
      Feb 18, 2018 | Frigidaire Freezers
      20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
      Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
      May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
      Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
      119 people viewed this question
      Top Frigidaire Freezers Experts
      Charles T Nevin
      Charles T Nevin
      AJMAL KHAN
      John Tripp
      John Tripp
      Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
