Question about Science & Laboratory
Dow corning hotplate - Science & Laboratory
Put all new orings in D51845 and worked for a few rounds then piston seized. Any ideas?
New O rings and lubrication ? best is to use a sillicon based lubrication like OKS 1110 or dow corning dc4 the top on and valve above the cilinder is very important to know that the rings and valve are working good flexible and its very ultra clean by this model .
The buffer on the bottom is closed enough to positioned right
pos 9 390159-00 Description: SEALVariant Description: CHECKPieces in Tool: 1List Price: $1.74 this seal is outside the cilinder was that changed to ? pos 1 Close1) 390140-00Description: SEALVariant Description: CYLINDERPieces in Tool: 1List Price: $2.81 is also important
Mar 18, 2016 | Tools & Hardware - Others
Corning Pc-320 hotplate/stirrer. Where can I get a manual?
Why do you need a manual there is nothing to do. To make the stirring function work, you need a magnetic stir bar (just a Teflon coated magnet. There is a motor-powered spinning magnet under the ceramic plate.
The heater is not thermostatically controlled. It just heats more as you turn the dial more.
May 17, 2015 | Corning Pc-320 Laboratory Stirring Hot...
Senoc finishpro 10 driver won't retract
http://www.senco.com/docs/retired-manuals-and-parts-charts/FinishPro10_PC.pdf
In most cases part BC0582 is the part it hangs it must be cleaned out and lubricated the whole AC0376 top of the nailer must be cleaned (solvented) and cleaned and basic grease a good silicongrease like OKS1110 (prefered) or Dow Corning DC4 Kluber Silubrin only that part because most models of Senco are oilless only if they have a kevlar pistonseal.
Feb 16, 2014 | Senco Air Tools & Compressors
Senco pro frame 601 just blows air when trigger is pulled
Senco nailers are mostly not lubricated but moisture and dirt do they have the neck compressor not tapped in time and then inside the top cover of this tools can have that or the parts are hanging can not move freely and clean, solvent them out and grease it with silicon OKS1110 Kluber Silubrin or Dow Corning DC4 in most cases the models of Senco are oilless IF the seal of the piston is made out of kevlar instead of a plain o-ring .
Jan 20, 2014 | Senco 1G0003R FactoryReconditioned...
Where to oil a senco accuset a200bn
If a kevlar piston (driver) ring is used instead of an ordinary O-ring there is no oil used but only a littlebit basic silicon-lubrication into the cilinder oks1110 or dc4 (Dow Corning) but no oil neccesary Most Senco's have kevlar these are gray flat (strips) rings with sometimes an little o-ring thereunder .
Oct 31, 2013 | Senco Air Tools & Compressors
Inner glass has come off and needs glueing back on. i need to remove the door to take it to the appliance repairer. what silicone or fire proof glue can i use?
Thanks for choosing FixYa,
Kelly
If your oven is not self cleaning use this one:
http://ovendoorglue.com/
Otherwise use this one:
DOW CORNINGĀ® 3-6096 ADHESIVE
Call Dow using this number Toll Free: 1-800-248-2481
and ask what retailer near you would carry this product:
Lowes, Menards, and Home Depot all have high temp silicone adhesives. You need one that has a temp range of 300 deg C / 572 deg F.
There are Black and Clear adhesives. I prefer the Black as it will not show grease signs ever.
Kelly
Mar 21, 2011 | Ovens
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
Mar 06, 2011 | Ovens
The left front burner will turn on for a few seconds then turn off then back on and off. It would not heat the pan on it. This is a glass top range. Are there any tests that I can do to find the problem?...
If the rest of the hotplate elements are working correctly and you are performing the same tests with all of them then you have a problem. We know that the hotplate works. When hotplates are faulty they don't turn on and off, they just don't work. This would generally be a hotplate controller problem. It sounds as if the controller is faulty and requires replacing. If you are handy you can switch the suspect hotplate controller with a good one and see what happens. This will confirm our suspicions.
Mar 04, 2011 | Kenmore 96412 / 96414 / 96419 Electric...
Tv problem
high voltage leakage around tube.
remove anode, clean area, Dow Corning 4 or silicone.
Sep 07, 2008 | Toshiba 32A33 32" TV
Science & Laboratory Logo
342 people viewed this question
Top Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
