Question about Roper REX3614KW Electric Dryer
Not heating up, changed element, and lent trap and exhost ok
    Sergeant:
    Champion:
  • 208 Answers
Make sure it's plugged in good. if it is get a electrician to inspect your lead from the breaker box to the dryer outlet as it may not be fully supplying the dryer with proper voltage
Posted on Jun 22, 2009
Why isn't my dryer drying anymore?
Clear the vent hose to the outdoors- clean the lint trap - if all vents are clear, your temp safety switch is cutting off heat (for a reason) If dryer is 5 yrs orolder - replace with higher rated energy saver - it will pay off.
Jan 15, 2018 | Dryers
My Kenmore 110.62212101 Dryer won't dry my clothes. My heater element does not come on at all and my lent trap is clean.
There may be a blown fuse, but most likely the heater element is burned out. They're not very expensive and pretty easy to replace.
Oct 23, 2014 | Dryers
Where is the lent trap on the estate washer
If it is like my Kenmore washer, you need to remove the front panel at the base of the machine. You should see the trap front and center, caution when you open the trap there will be water coming out. good luck
Sep 06, 2014 | Estate Washing Machines
WHEN DRYER STARTS IT WILL RUN FOR A LITTLE WHILE AND SHUT OFF. YOU WON "T BE ABLE TO START IT FOR A LITTLE WHILE. AND WHEN IT STARTS AGAIN IT WILL WORK SOMETIMES.
there is a protection device called a thermal control it could be ovreheating because of an internal clogg or thermal fues located in rear or the heating elements and also check lent trap, check this first
Sep 02, 2010 | Kenmore 62802 Electric Dryer
My dryer is working, but it's not heating
pull the vent line off the back of dryer and see if it helps,also the duct that the lint filter slides into could be loaded with lint,when was the last time you cleaned out the dryer?sounds like from what you said when you had the top off it worked better because you had better air movement with the top off.go out side and check the vent,if it's a long run from the back of the dryer to the outside vent i use a leaf blower to blow out the vent line,you also need to vac out the inside of dryer where the motor is,if you have a shop vac blow off the motor and blow through the inside vent to clean out the heating duct and vac out the back of the drum,you should take it apart and clean it out once a year so the dryer will run correctly
Mar 27, 2010 | Frigidaire GLER341A Electric Dryer
Heating problem with kenmore elite he4 electric dryer. drum turns, lent trap clean, heating element ohms ok, thermo coupler ohms ok, thermostat ohms ok, timer counting down. still no heat.
limit switch stuck open should be behind motor housing is a tight fit to get to but there are two there on the element one on vent tube the other is thermal switch recommend chang the two on the tube ck element limits should all read continuityif not reolace
Jan 26, 2010 | Kenmore Elite HE4 Electric Dryer
My Hot Point Dryer keeps shutting off while the clothes are still wet. When I go to restart it will not start until it cools off. We took the dryer apart cleaned it all out and we always make sure the lent...
Thermostat controls heat. There is also a
motor centrifugal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The element has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 13, 2009 | Dryers
Power going to switch but no action in the drum
check the belt, it may have a broke belt switch.
Nov 24, 2008 | Kenmore 63942 Dryer
Dryer doesn't dry
YES, most defintely. This typically causes the dryer to overheat and eventually blows the thermal cut-out or heating element.
SYMPTOMS:
Dryer runs, but does not heat - possible bad heating element or thermal cut-out.
Dryer does not run at all - possible bad door switch, blown thermal fuse, timer or drive motor.
Does your dryer exhibit any of these symptoms? Please post back and let me know.
Feb 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Roper REX3614KW Electric Dryer Logo
117 people viewed this question
Top Roper Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Roper Dryer Expert? Answer questions, earn points and help others
