Question about Canon P23-DHV Calculator
How do I get rid of an "E" on the display when I switch to print and the keys lock. how do I fix it?
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Mar 27, 2016 | Pentax Optio E30 Digital Camera
I have a Telefunken flat screen tv. Using remote message 'key lock' is displayed. How do I get rid of this?
hi there try this link they can help you
http://www.telefunken.com/service/
Jun 27, 2014 | KLH 13" TV
How do you reset anti theft on a 2007 equinox
TURN ON IGNITION SWITCH TO ON POSITION.ENGINE OFF.REPEATEDLY PRESS VECHICLE INFORMATION BUTTON UNTIL PRESS TO RELEARN REMOTE KEY IS DISPLAYED.PRESS SET RESET BUTTON UNTIL REMOTE KEY LEARNING ACTIVE IS DISPLAYED. IF THAT PROCEDURE DONT WORK.INSERT MASTER KEY INTO IGNITION SWITCH.NOW SWITCH IGNITION ON SWITCH IGNITION OFF.REMOVE MASTER KEY.WITHIN 10 SECONDS INSERT NEW KEY.SWITCH IGNITION ON.ENSURE SYSTEM WARNING LAMP SWITCHES OFF.NEW KEY NOW PROGRAMMED.IF YOU STILL HAVING PROBLEM RESETING THEFT SECURITY SYSTEM THE DEALERSHIP HAS TO FIX.REPROGRAM IT.
Mar 14, 2011 | 2007 Chevrolet Equinox LS New Cars
Textos distorcionados
Sympton: Horizontal misalignment of characters (Dots or characters move left or right from dot row to dot row or line to line)
NOTE: to check the phasing value, power down the printer, remove
the shuttle cover, and read the phase value on the aluminum
shuttle casting in a black marker. Should start with PH... You will need this number below!
IMPORTANT The printer must be printing the Phase pattern of “H’s” when the Phasing Value is changed, or the New Phasing Value will not be written into NVRAM. If the value is changed when not printing, the printer will return to its default phasing value when powered off then back on.
1. Raise the printer cover.
2. Install the ribbon.
3. Load full width (136 column) paper and set the top of form.
4. Power on the printer.
5. If the printer is on-line, press the ON LINE key to place the printer off-line. “OFFLINE / CONFIG. CONTROL.” displays.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/unlock key combination can be programmed by the user. If = + > does not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the test begins. The current phasing value is printed on the left of the printed pattern of all H’s. As the pattern prints, compare the H’s to the figure below. If the phasing needs adjustment, go to step 12. If the phasing is OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*) appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press ENTER to activate the value as it prints. Continue to increase or decrease the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). *ENTER SWITCH LOCKED” briefly displays.
18. Close the printer cover.
19. Press the ON LINE key to place the printer on-line.
NOTE: If you changed the phasing value, power down the printer, remove
the shuttle cover, and write the new phase value on the aluminum
shuttle casting.
Apr 26, 2010 | Printronix Line Matrix P5005B Printer
Message reading change drum soon permanently on screen. changed the drum as no printing could be seen, ie paper blank. however, still got the change drum message on the screen. how do i get rid of this?
7 Wait until the time, date and answering mode appear on the display. Then press the SELECT FUNCTION key. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 8 Press the 7/COUNTER DISPLAY One-Touch key. The display will show DRUM COUNT. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 9 Press 2.413c?openelement&fieldelemformat=gif to clear the image drum unit
counter. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 10 Press the SELECT FUNCTION key to finish. ecblank.gif
Dec 03, 2009 | OKIFAX 4500 Plain Paper LED Fax
My printronix printer making shadow while printing
Hammer Phasing Adjustment:
Important: The printer must be printing the Phase pattern of “H’s” when the
OK, go to step 15.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
shuttle casting.
Jun 04, 2009 | Printronix Line Matrix P5005B Printer
Hello, I have characters printing trouble, so that I would like to restore the factory default settings for my printer Tally 2280. But I do not know the procedure to do so. I need Helps, very...
You can reset the menu on the 2280 to factory default settings, but I would strongly recomend first printing a menu print to ensure you know how the menu is currently set up.
The menu can be printed in the follwoing way;
Switch the printer power on.
Press the Setup key to enter the menu settings.
Press the key under "Menu",
Then press the key under "Print" and your current configuration will be printed.
If the menu is locked power the printer on holding down the setup button, this will unlock the menu.
To restore the factory defaults within the printer,
switch the printer off.
Press all four keys beneath the printer display and switch on the printer.
Keep the keys pressed until "Initializing" is seen in the printer display.
Your printer is now set to the factory default configuration.
Jan 27, 2009 | TallyGenicom 2280 Matrix Printer
Print is clear and fuzzy
I'm sure you have fixed this by now... But solution is...
Check the hammer phasing. Adjust hammer phasing if
necessary.
OK, go to step 15.
LineMatrix
Sinca Printers, Parts, & Repair
www.sinca.biz
Jun 11, 2008 | Printronix Line Matrix P5215 Printer
What are the hot keys to switch between PC's?
You might try Scroll Lock twice followed by Up and Down Aerrows
Scroll Lock + Scroll Lock + Up or #1 or #2... and Scroll Lock + Scroll Lock + Down or #1 or #2 to switch b/w comps
Feb 15, 2007 | IC Intracom 156752 4-port KVM Switch
Canon P23-DHV Calculator Logo
53 people viewed this question
old marine
old marine
