Question about HP Officejet J4680 InkJet Printer
HP j4680 all in one printer constant Paper jam message
I have a hp j4680 all in one printer and it constantly flashes the error message Paper jam:clear jam and then press ok. Have cleared all paper and reset using 3 and # and also 6 and # and the above message still appears am not able to clear it whatever i try still not able to clear it. can you help me please ??
  • thirstyann Jun 22, 2009
    Hi, Thanks for the help but none of these have worked, I have been on the HP site and tried everything. I have read somewhere that it may be something to do with the paper sensors but am not sure where they are or what they look like to see if they had stuck?? can you help?
Based on encouragement from olsnake above, I fixed it easily. It definitely WAS the encoder wheel (a thin clear plastic disk printed
with timing marks) on the left side of the paper-feed roller, as you look at it from the front. This wheel provides motion feedback to the paper feed control software. If the disk is detached/loose, the device thinks the paper feed roller is stuck or impeded, and thus gives the annoying error.
What I did:
1) Remove the scanner assembly (it comes off with a few screws, and is a totally separate unit; The printer works with it completely disconnected (after it complains that the scanner is malfunctioning). Beware that you don't break off the little control panel. Or you can be safe and remove the one screw holding it on, by prying off the 'HP OfficeJet...One" plastic cover.
2) Once you have removed the scanner assembly:
at the left side you will see three white plastic gears meshed together; the farthest one is covered in a circular black
plastic cover. With some care you CAN remove this cover without any additional screwdriver work.
3) in my case (and most others I bet) the thin disk was detached from the gear to which it should be attached. I just shoved it back on, so it was tightly mated to its white gear. You should also ensure that the clear disk goes through the optical sensor at the bottom (mine was).
4) I did not bother to replace that cover, if you can do it, good for you.
5) Test, and reassemble.
This is about the WORST product engineering imaginable. But I have a working printer again!
Posted on Jan 17, 2010
  • 4 Answers
Encounter same problem with J4680 after a year of use, right after warranty. After couple days of debate to myself for buy a new one or get my screw drivers out, I went try the latter.
Problem found: The timing wheel is falling off. The timing wheel is a piece of Mylar film that has timing mark on the outer edge. The edge of the wheel is positioned in a optical pickup. It is used for provide feedback of paper feeding speed/location to the controller. The design of J4680 merely uses a thin coat of adhesive to attach the timing wheel on one of the Nylon gear face. It did not hold. Put back the wheel and adding a small o-ring on the shaft for additional security. Now the paper jam is gone and the printer works like before.
The timing wheel is inside of a black plastic cover at far left of printer. Since I had hard time to remove printer and end up repair it in place, it may not be the job for everybody. It just a bad design in my opinion and should qualify for a recall. The adhesive can fail fair quickly due to the environmental condition (temperature, humility and on…). You don’t have to use it to make it fail. That maybe why some of them fail in couple of weeks and others took longer (god knows how the printer was stored and transported).
Posted on Dec 15, 2009
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
This video should help...
Posted on Dec 23, 2009
    Problem Solver:
  • 14 Answers
Clutch might be broken..causing noise while cleaning procedure..plastic clutch to be replace..
Posted on Jan 23, 2015
    President:
  • HP Master
  • 1,996 Answers
You may need to clean the printer. Please see these instructions.and these.and these.
Try resetting the printer by shutting it down, disconnecting both power and data cables for 5-10 minutes, then reconnecting and restarting.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 22, 2009
  • efs_perpends
    efs_perpends Jun 22, 2009
    Please have a look at some of the solutions posted in the HP forum, like here, here and here.
    Sometimes you have to be very persistent to clear these jam messages. Shut it down, disconnect, shut down your computer, go have a cup of coffee or something, then come back and initialize. Try pressing the ok and stop buttons on the printer control. Make sure the print queue is cleared., etc.
    Then things shouldn't be as finicky as they are, but they seem to be. I have heard of people who kept resetting over and over until it finally worked...but couldn't explain why....
    I hope this helps somewhat!
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
Paper jam message
Is any of the buttons on your printer flashing?
you might have a cartridge problem
Mar 04, 2010 | HP Photosmart C4150 All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP Officejet J4680 InkJet Printer Logo
3,042 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
