Question about SWANN DVR-415 ThumbCam Mini Digital Video Camera
What is the format for the DVR-415 time set? - SWANN DVR-415 ThumbCam Mini Digital Video Camera
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
You will need to connect to a PC, then open the notepad file and change the time carefully. Safe the notepad file and the correct date and time should be set.
Posted on May 17, 2016
My H264 network DVR DH 3004 has reset it self to Chinese, how do I factory reset back to English? Thanks
Set the system parameters such as general setup, code setup, network setup, network service, output
mode, PTZ control, serial port setup and alternate patrol setup.
See the window pop ups. Here you can select the language from the drop down window
[systemtime? Set the system data and time.
? dataformat? Choose the data format:YMD,MDY,DMY.
? listseparator? Choose list separator of the data format.
? timeformat? Choose time format: 24-houror12-hour.
? language? English or Chinese.
? harddiskfull? Choosestop:Stop recording when the hard disk is full.
Choosecover: Coverthe earliest recording files and continue recording when the harddisk is full
[number? Only when the address button in the remote controller and the corresponding DVR number is
matched,the remote operation is valid.
? videoformat? PALorNTSC.
? latencytime? Set the latency time in 0-60.0 means no latency time.
? summertime? Choose the summer time option and pop the dialog box as followed.
For more details, refer its user manual.
https://electronicshelponline.blogspot.com/
Sep 12, 2016 | Home Security
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
Tech support
DVRs store files on either data tapes or on hard drives or on memory chips such as SD cards. If SD card then simply remove the card and plug into a computer where it will appear as a removable drive. If internal hard drive your DVR will be equipped with either a IEEE1394 mini socket or a USB mini socket. In either case plug the appropriate cable from your DVR to your computer where it will appear as an external removable drive. If you are talking about a proprietary DVR such as a Foxtel IQ or other brand name DVR then you have to know the format of the video files. Foxtel, for example, uses their own format which can be recovered and saved to an external hard drive on a computer using a video capture card and playing the file back in real time. Time consuming, but that's how I do that. Other branded DVRs use standard video file formats that can be copied to your computer easily via an HDMI socket or USB3 or whatever it has.
Dec 09, 2013 | Audio Players & Recorders
Lost my booket and just want to know if the DVR410 has batteries or a charger.
The DVR 410 uses three AAA batteries. You can use rechargeable batteries, but you'll have to charge them using a separate charger.
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/415/DVR_410_Camera_Manual.pdf
May 28, 2011 | Vivitar Cameras
Is the vivitar dvr 530 compatible with sdhc cards
Plug the SD card with contact terminals facing away from battery. It most likely is using internal memory which is much smaller. All cards under 4gb are normal SD. The camera should be able to format the card, or use an adapter and windows will format (default settings).
Jan 03, 2009 | Vivitar DVR 530 Flash Media Camcorder
DVR 1600
Start by checking the DVR format compatibility list, see if the dvd format matches. The check DVR settings for playing features that can be adjusted. Try other DVD's that have worked on your DVR previously.
Jan 10, 2008 | Cyberhome DVD Recorder - DVR1600
Cyberhome 1600 DVR Format problem
Heat related.  Google "Cyberhome DVR-1600" "power supply" (with the quotes included) for answers...or look elsewhere in this forum.
Jun 30, 2007 | Cyberhome DVR 1600 DVD Recorder
SWANN DVR-415 ThumbCam Mini Digital Video Camera Logo
109 people viewed this question
Top SWANN Home Security Experts
Electro Med Services...
L Pfaff
L Pfaff
Da Doc
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
