Question about HP Officejet Pro L7580 All-In-One InkJet Printer
How do you clean printhead on hp l7560 officejet pro
Techvisitor
  • 63 Answers
SOURCE: The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Posted on Oct 31, 2008
SOURCE: I have an HP Officejet Pro 7580. When printing in
Press "set up" button until number 6
Number 6 is "tools"
press OK
press forward arrow (to right of ok button)
No.2 is clean printhead
No.3 is align printer
No.4 is calibrate line feed
Posted on May 04, 2009
SOURCE: HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Posted on Dec 29, 2009
  • 159 Answers
SOURCE: HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Posted on Mar 15, 2010
PCTechOnline
  • 532 Answers
SOURCE: Printhead Problem:
Have you tried to replace the black/yellow printhead? This is not the same as the ink cartridges, but it is located in the compartment under and to the right of the scanner lid.
Here is HP's link.
Posted on Mar 21, 2010
Hp officejet pro 8500a shows cleaning print head/alining print head
that might be your printing settings and laptop file formate
Mar 17, 2016 | HP Office Equipment & Supplies
HP officejet pro l7850 wont print black
are you using hp original cartridges? if not, then thats probably the issue!
Jun 30, 2012 | HP Officejet Pro L7680 All-In-One Printer
Hp officejet pro 8500 cleans printhead everytime i turn it on. and it uses ink! how cani deactivate it? how can i set to cleaning it manually?
That is quite normal . All inkjets run a cleaning cycle when turned on to make sure there is a good flow through the printhead and to prevent the head from becoming blocked. You cannot turn it off.
May 24, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro K550 - Printhead Error Message on new printhead - cleaned printhead, contacts... tried all fixes... what now? Is it faulty?
I have the same problem. I replaced both printhead cartidges. The MC light stopped blinking, but the KY light kept blinking. I thought it was a faulty new KY ink cartridge. So I returned that cartridge and got a new one. Still the same issue. I called hp and they said the print head is bad now and all they focused on was trying to sell me a new printer. UG! I also heard wiping off the printhead with a dry cloth may help. Did you get yours to wokr?
Jan 27, 2011 | HP OfficeJet Pro k550 Printer
How do i clean the printheads on a hp officejet
hp printers have a utility program that cleans and purges the printer heads. Go to HP on your startup menu and look through the options....mine is located in the "hp solutions center".
It has an option for purging the printer heads.
Jul 07, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Number 6 is "tools"
press OK
Mar 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My HP officejet Pro L7580 says the printhead has a problem
Re-insert the print cartridges. It is also possible that the heads are burnt. Get a new set of print heads (black/yellow) and install to the printer. If problem persists, clean the contacts on the printers. Use acetone + cotton swabs.
Mar 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
