Como conecto tanque de gasolina en una suzuky 1985
Como van las mangueras
SOURCE: LAS LUCES EXTERIORES NO ENCIENDEN
i am getting the problem in graphic card . dispaly cannot change ,and cannot change setting in display , plse give solution or solve this problem.
Posted on Feb 05, 2009
arauzvictor1
  • 466 Answers
SOURCE: consumo de gasolina y diagrama de las mangueras de
Especifica el motor y el sistema de inyeccion que tiene instalado ya que estos varian deesa forma te podre alludar
Posted on Nov 12, 2010
ryanlutton
  • 1139 Answers
SOURCE: como cambio la bomba de
Losiento mi espanol is mal. Porque to es cambio la bomba? Yo no sabes nadian, quien necisito cambio asi especial porque asi carro es como nuevo. Que es original problema?
Posted on Nov 30, 2010
ZJLimited
  • 17970 Answers
SOURCE: manguera de vacio
Hay varios tamanos de motor alli, 2.2L y 2.5L con o sin Turbo... Sugiero revisar este enlace AQUI.
Suerte.
Posted on Jul 16, 2012
ercupa190
  • 12223 Answers
SOURCE: liquea gasolina por la parte superior del tanque de gasolina dodge durango 2005 motor 3.7
follow the steps for fix it. God bless you
Instructions
    • 1 Drive until your gas tank is nearly empty, ideally until the fuel level is below the gas tank leak, if possible. You can determine this by routinely stopping and checking for oil leaks. If oil is still leaking, the gas tank is still filled above the leak. Use brake cleaner to clear 6 to 8 inches around the leak. Wear gloves and protective glasses while you work. Do not let your gas tank completely empty before you perform repairs.
    • 2 Use a scraper and sandpaper to remove road tar, rust or grime around the leak. Use brake cleaner on the area again and allow it to dry
    • 3 Remove the epoxy from its packaging, taking the same amount from both sticks. Mix the epoxy together, massaging it between your fingers until it is the same color.
    • 4 Form epoxy into a cone shape and push it into the hole or leaky area. Use a plastic spreader to smooth the remaining epoxy into place. Allow the epoxy to completely cure. If the leaking problem persists, take the car in for professional repairs.
Posted on Oct 18, 2012
Ayuda tengo una mercury villager 1999 y mi problema es que me esta acumulando gases en el tanque de combustible quito el tapon de gasolina y salen los gases..ya revise las mangueras de vacio y las que ban...
si dejas bajar el tanque al minimo el tanque queda vaco y por temperatura va a generar presion si no da codigos el systema de raciclaje de gases supuestamente esta trabajando
Nov 07, 2014 | 1999 Mercury Villager
Que sinigfica po442
Hola:
P0442 - Evaporative Emission Control System Leak Detected (small leak)
Lo del codigo es una falla del control de emisiones puede ser que el tapon de gasolina ya no este cerrando bien o alguna maguerita del canister se desconecto, no es nada que ocasione gran falla. Esto indica una fuga de vapor de combustible en el sistema de control de EVAP. De hecho, la filtracion puede ser de un agujero tan pequeno como 0,04" de diametro. El sistema de emision (EVAP) de control impide el escape de vapores de combustible del sistema de combustible de un vehiculo.
Los vapores del combustible son enviadas por medio de mangueras a un filtro de carbon para su almacenamiento. Mas tarde, cuando el motor esta en marcha una valvula de control de purga se abre para permitir entrada de la aspiracion para extraer los vapores de combustible en el motor.
Sintomas: Es probable que no se dara cuenta de los problemas de manejo.
Causas: Un codigo P0442 medio mas probable de uno o mas de los siguientes ha ocurrido:
Un gas suelto o colocado indebidamente el tope
Un disconforme de gas de cabeza (es decir, no de fabrica / marca original)
Una pequena fuga / agujero en una manguera de vapor de combustible / tubo
Otra fuga pequena en el sistema EVAP
Ventilacion defectuosa o-ring
Posibles soluciones: con un P0442, la reparacion mas comun es:
Retire y vuelva a instalar la tapa de la gasolina, borrar los codigos, y la unidad por un dia y ver si los codigos de volver.
De lo contrario, vuelva a colocar la tapa de gasolina, o
Inspeccione el sistema EVAP de cortes y agujeros en los tubos o mangueras
Espero que esta informacion le sea de ayuda. Suerte, y recuerde calificar esta respuesta.
Gracias por usar FixYa.
Jul 15, 2012 | 2000 Ford Explorer
Que significa chekch
Una señal luminosa "check engine" le está diciendo que la computadora que controla el motor de su auto ha detectado un problema que causa que el vehículo produzca excesivas emisiones. En ocasiones la luz será acompañada por una notoria serie de problemas en la respuesta del carro, como pérdida de poder del motor o dificultades para encender, pero otras veces el vehículo puede operar "normalmente".
Las fallas comunes que pueden causar que se encienda el "check engine" incluyen:
- Falla en componentes del motor como los sensores de oxígeno, temperatura del refrigerante, presión interna (MAP) o de flujo de aire.
- Motor que no enciende debido a fallas en las bujías, cables, componentes del encendido, inyectores de combustible u otras partes del sistema de combustible.
-Fallas en el sistema de control de emisiones como mangueras de vacío rotas o sueltas, el tapón del tanque flojo o desaparecido, o una defectuosa válvula de recirculación de combustible (EGR).
Si se enciende y luego se apaga tras unos instantes, puede ser un problema momentáneo en el sistema. La luz se apaga cuando el problema se detiene, pero la computadora debe haber guardado un código de diagnóstico de problema en su memoria. Si la luz no regresa, puede ignorarla. Sin embargo, si la luz se enciende y apaga intermitentemente, lleve el vehículo para que lo revisen y puedan escanear el computador para determinar que codigos de falla hay almacenados en el.
Suerte (recuerca calificar y comentar esta respuesta).
May 14, 2011 | 2004 Chevrolet Impala
Limpieza de inyectores
Para una limpieza de injectores hay differentes formas de hacerlo. La mas barata y la que puedes hacer tu mismo es la siguiente: Ve a tu venta de auto repeuestos mas cercana como por ejemplo autozone y pregunta por un aditivo para limpiar los injectores. Luego ve a la gasolinera y llena el tanque con la gasolina de mayor octanaje y pon el contenido del aditivo en el tanque tambien. Trata de gastar todo ese tanque de gasolina con aditivo en carretera abierta donde puedas correr a alta velocidad como en el freeway. Eso te ayudara a limpiar injectores sucios y si ese era tu problema veras el cambio positivo despues de haber echo este procedimiento. No recomiendo hacer este procedimiento de limpieza de injectores a carros que no lo necesitan o carros que no tienen problemas en el sistema de injeccion.
No te olvides de darme puntos en el rank esto me ayudara a dar mas respuestas a personas como tu. Gracias!
Feb 25, 2011 | 2000 Pontiac Grand Am GT
Tengo un motor vortec 4.3 de safari1995 kiero encontrar la falla me pueden ayudar ya limpie el tanke cambie filtro limpie los inyectores y si gue tenblando en carretera falla como si no trabajaras los...
ok tu falla es facil solo cambia la bomba el cedaso de la bomba y el filtro de gasolina tienes que limpiar tu tanque de gasolina y evita ponerle aditivos ya que todas las uinpuresas se van alos inyectores son muy delicados y cambia bujias
Dec 20, 2010 | 1995 GMC Safari
Cuantos litros de aceite y que tipo de aceite lleva una jeep patriot 2008 4 cilindros gasolina y donde se encuentra su filtro de aceite y gasolina
hola que tal el filtro de gasolina lo traen arriba de una tolva que se encuentra exactamente por las ruedas delanteras ( abajo del motor) quitas esa tolva y es de lo mas facil cambiar el filtro y el aceite,, el de gasolina si esta un poco mas complicado pues esta dentro del tanque. lleva aceite del que quieras un 20w50 estaria bien depende de que kilometraje lleve pero mejor ponle un sintentico...
Sep 18, 2010 | 2008 Jeep Patriot
El aire acondicionado de mi trailblazer 03 no funciona en las ventanitas de enfrente solo en las de abajo para los pies...cual puede ser el problema?
El vacío se utiliza para cambiar el flujo de aire a los respiraderos. Suena como usted tienen una manguera de vacío floja o disconnected en el lado trasero de los controles.
Jul 22, 2009 | 2006 Chevrolet Trailblazer Ext
Como poner cadena de tiempo a motor de ford ranger 2003
Como loner el filtro de gasolina En 2003ford focus
Apr 30, 2009 | 2003 Ford Ranger Regular Cab
21 people viewed this question
 Grubhead
Grubhead
