Question about Sanyo DP50749 50 in. Plasma TV
Yes I have a DP 50749 sanyo plasma tv 50 inch the green power led comes on for 20 seconds goes off. then it sounds like relay on the main power board starts a clicking noise Then it stops clicking and the green power light comes back on and the cycle starts all over all the fuess on the power board are good. I am not a technicson my skills are limited to what I can do does this power supply have 2 LED lights on the board?
    Master:
  • Sanyo Master
  • 505 Answers
This is likely a heat issue, and the CPU of the tuner is instructing the power board to switch it off for reasons related to over heating. Check that a fan ventilation improves the problem. The solution is not easy but maybe adding a fan to the tuner CPU can fix this issue.
Posted on Jan 02, 2015
Slapnuts1975
  • 51 Answers
SOURCE: Sanyo main board
Sanyo 1-800-877-5036
Or... www.shopjimmy.com for used parts.
Posted on Aug 06, 2008
waynejamescm
  • 67 Answers
SOURCE: Have a Sanyo Plasma TV
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
I hope this helps you...
Posted on Jan 10, 2009
  • 92 Answers
SOURCE: 50 inch Sanyo Vizon Plasma TV. Has sound but no
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Posted on Sep 06, 2009
Testimonial: "Thank you for your response. We were driving ourselves nuts - fuzes checked out fine and not other guess where to turn. We appreciate your help!"
  • 22 Answers
SOURCE: Sanyo DP50747 Replaced Power Supply still not working
this issue is related to either the y sustainer and z sustainer boards, checking the fuses on the y/b will giving you a good indication, if they are open(bad) then you'll have a easy fix, if not, i would try replacing the y board first.
Posted on Apr 16, 2011
  • 8457 Answers
SOURCE: have a sanyo 50" plasma
This tv problems are related to powering up the tv and sustancening the tv power source to the tv itself.Replaced the tv sub power supply board where the a/c power cord plug into it.Try website like Ebay.com to buy a whole new refurbish sub power supply board for the replacement.
Posted on Sep 06, 2011
SANYO DP 50710
Sounds like a bad main board !!!
Jul 28, 2012 | Sanyo DP50747 50 in. Plasma TV
Turning on tv on a morning is a night mare led is on red press remote light goes off for about 20 mins then comes back on try turning on again goes to green light for 20 seconds then turns off again this...
usually is an issue with the power supply or power inverter for the tv. basically one of the capacators is not holding a charge like it should and is causing the power to drop. contact a repair technition or begin looking for a new tv.
Mar 07, 2011 | LG 50PG20 50 in. Plasma HDTV
Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
Apr 12, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
I need to set up my tv remote for my new sanyo 50 inch plasma and I threw away my manual by accident. It is model 50749. thank youl.
Here's a link to the manual (I always toss them, too)!
http://us.sanyo.com/dynamic/product/Downloads/DP50749%20OM%20(332--)-45914968.pdf
Hope this helps!
Rate my solution!
Jan 05, 2010 | Sanyo DP42746 42 in. Plasma Television
I have same problem. Walmart is selling Sanyo junk You are not alone lots of web chatter about these lasting 2 years or less, Mine lased 19 months, Trash it & buy a different brand. I originally was going to buy a Samsung & now I will.
Sep 22, 2009 | Sanyo DP50747 50 in. Plasma TV
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Sanyo DP50749 50 in. Plasma TV Logo
136 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
