Question about Conair Thinner Scale by TH200 Digital Precision Scale
Thinner th300m resets to 12:00 - Conair Thinner Scale by TH200 Digital Precision Scale
How many btus per sq ft?
12,00 per 400 sq.ft.
Sep 12, 2015 | Heating & Cooling
Need to reset the weight on the conair th300m. already replaced the battery
Actual weight is detected by a pressure transducer which may have failed. The constantly changing readout indicates there may be a problem with the internal circuitry.
Jun 16, 2014 | Weight Watchers Glass Electronic Scale
Mitsubishi dion.the vehicle can't start
is many things which can result in not starting.
1) check if ur starter motor cranks if it does ,check for spark.
2)if the starter doesnt check your battery state by using a multimeter take the readings if is 12,00 volts or more is good
3)check your battery terminals contacts against the battery poles if bad use hot water pour over them but extra careful is needed because some of electronic component hates water
Dec 01, 2013 | Cars & Trucks
Can you translate the model number please
I cant tell you the date it was made, only from the serial number. But the 036 tells me it is a 3 ton unit. There is 12,00 btu per ton of cooling, so on your carrier, 3x12=36, which will be the 036. That's about all I can give you on the number.
Shastalaker7
Nov 21, 2011 | Carrier 38CKC036 Air Conditioner
No internet connection
First step : try to repair open router clean the mainboard modules using lacqure thinner or contact cleaner.
second step : to check power supply of router for volts drop.try to change power supply.
third step : reset botton at the back of router press reset then power on router.
May 28, 2011 | Computers & Internet
I installed Printmaster 2011 platinum on my pc. Everything went well until I tried to print my project. I have an error message everytime that says: Printmaster 2011 Platinum 3.0.70 encountered the...
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224)
at java.lang.Float.valueOf(Float.java:388)
at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982)
at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386)
at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103)
at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
Oct 22, 2010 | Broderbund PrintMaster Platinum
How do i reconnect capacitor cbb65a-1 from my haier esa3125 12,00
The wires usually just have connectors that push on/pull off. Some capacitors run the fan and the compressor and have 3 different terminals. It is very important to make sure the wires get put back on the right terminals on this type. You can find a capacitor at a local heating and air store.
May 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
I have Windows 7 and just installed PrintMaster 2.0 Platinum. I cannot print anything. here is the error message. PrintMaster 2.0 Platinum encountered the following error: java.lang.NumberFormatException:...
I had the same problem. If you are using a french version of Windows, try to switch your regional settings to "English US". It worked for me. Every time we use an English software on a French version of Windows, we have compatibility problem... ;)
Good Luck!
Dec 21, 2009 | Broderbund PrintMaster Platinum
Maytag air conditoner
Unless you can see if the fan is hitting something, you can't. You will need to take it to a repair shop. Sorry.
Jun 09, 2008 | Heating & Cooling
Conair Thinner Scale by  TH200 Digital Precision Scale Logo
59 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
