Question about Microsoft Xbox 360 Console
My xbox has a orange light on the power brick but my xbox won't turn on
Your retarded
Posted on Jun 22, 2009
nealj121
  • 152 Answers
SOURCE: power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Posted on Apr 10, 2009
  • 5 Answers
SOURCE: XBOX 360 power brick flashing orange and green
according to the microsoft website:
The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply can turn itself off when there is too much current, too much voltage, or too high a temperature. Under these conditions, the light on the power supply will turn from green to orange or to red. Or, the light will turn off. When the power supply light is green, the power supply is working correctly.
To help the power supply work correctly, always try to use the following best practices:
  • Make sure that all ventilation openings in the power supply are free to ventilate.
  • Do not put the power supply on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
  • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
  • Plug the power supply directly into a wall outlet. In other words, do not use extension cords or power strips.
Basically, feel if it is overheated. if it is let it cool down. If not try a different wall socket. If that doesn't work you probably have a problem with your power brick or console. Try borrowing someone else's power cords.
Posted on Jun 15, 2009
  • 733 Answers
SOURCE: Xbox 360 has orange light on the power brick,no
Mine has an orange light and works fine. i think that's standby mode. it turns green as soon as the 360 powers up. try replacing the power cord that goes from the 360 back to the power block. It may be faulty.
Posted on Nov 21, 2009
  • 143 Answers
SOURCE: My Xbox 360 won't turn on. When I plug the power
Sounds like a bad power supply, or on two occasions I have found that one of the USB ports had a bent pin which was shorted to the metal housing, which wouldn't let the unit power on. So check all of the USB ports
Posted on Dec 04, 2009
damonumber5
  • 340 Answers
SOURCE: xbox won't power up, orange light is on the power
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Posted on Feb 13, 2010
My xbox won't turn on I have an orange light on
blow out the brick power supply with air
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Oct 05, 2013 | Microsoft Xbox 360 Console
When i plug the xbox up the light on the plug adaptot turns orange and the xbox wont turn on
This is usually caused by the power brick over-heating. Try cleaning out the vents on the power brick. There are little holes on the ends and overtime they become clogged with dust and lint. If that doesn't work then you'll have to replace the power brick.
Jan 29, 2012 | Microsoft Xbox 360 Hard Drive (120GB)
Xbox 360 won't turn on!! I was playing my xbox for all of 30 minutes, turned it off, went to turn it back on again an hour later, and nothing!! No red ring of death, no pop or spark, just nothing....
try this
I know its a little annoying but its useful trust me. The orange light usually means a problem with the power supply. This means WORST CARE SCENARIO you have to replace the power brick but you 99% dont have to get a new xbox.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/power.aspx
cheers!
May 15, 2011 | Microsoft Xbox 360 Console
My x-box won't turn on with everything plugged in
Hi check on the power brick that when you switch it on at the mains you get the orange light on the power brick, if you have this watch this light as you press the on button on the console if it turns red on the power brick then you have internal error on your xbox, if it stays orange then try taking out the power lead out of the back of the xbox 360 then push it back in sometimes if you dont get it pushed in far enough it wont work push it in as hard as you can then double check by pushing it back in then try pressing the on button.
if when you turn it on at mains you dont have any lights light up on the power brick then this could mean you either need to change the fuse in the plug or the power brick has over heated and needs replacing, if you do have an orange light on it then instead of pressing the on button on the xbox try pressing the dvd drive open button and see if that then switches it on.
let me know what light you get on the power brick and then ill do my best to assist you further.
most of the time its just because you dont push the power lead in the back of the xbox far enough, you can push it in thinking its in far enough when its not try pushing it in that little bit further and you should find it will come on.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Nov 15, 2010 | Microsoft Xbox 360 Console
The power brick on my xbox 360 is red and is not overheating yet i smaell burning plastic from my xbox 360 console anyone have any tips?
A red light on the xbox 360 power brick usually indicates the Xbox 360 console has a short circuit. Here is how to be sure:
1. Try unplugging the power brick from the wall and from the xbox 360.
2. Wait about 30 seconds and plug the power brick into the wall power outlet.
3. Make sure the indicator light on the power brick is orange. ( If it's not orange then get yourself a new power brick and try again ).
4. Plug the power brick into the Xbox 360 console and try to power it on.
If your power brick turns red or you get an immediate three red ring error than you will need to have the console professionally repaired.
If your warranty with Microsoft has expired; the company I work for GATpro Repairs offers this service at a low flat rate and we pay for the return shipping.
Good Luck and I hope this has helped!
Michael GATpro Repair Technician
Jun 14, 2010 | Microsoft Xbox 360 Console
Xbox won't power up, orange light is on the power brick
Feb 13, 2010 | Microsoft Xbox 360 Console
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Dec 08, 2009 | Microsoft Xbox 360 Console
My Xbox 360 won't turn on. When I plug the power cable into the wall, the orange light on the power brick lights up as normal, but if you plug the other end into the Xbox, the orange light starts blinking....
Dec 03, 2009 | Microsoft Xbox 360 Console
My xbox 360 will not turn on
try someonw elses power supply and see if it works. Orange light can still work and it not put out the power to the xbox.
Sep 22, 2009 | Microsoft Xbox 360 Console
What color should the light on the power brick be? I am new to the 360s so im unsure. The light on the power brick is orange. I just bought it
Well the Power Brick in Orange because the console is truned off, signaling the "Brick" is on standby. Or the Orange light can mean the "Brick" is not connected to the console.
Dec 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
328 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
