SOURCE: I have an Amana NED7200TW Electric Dryer that was
You probably busted the element during the move and this not a serious problem. These parts are fragile and easy to repair. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.Call us from 7 AM until 9 PM CST. We hope to help you repair your dryer. Thanks, Ella
SOURCE: My Amana NED7200TW dryer still shuts down with no
Hi and welcome to FixYa. The symptom you describe can be caused by several things.
If the belt is getting loose the belt switch can cause it to shut down completely with no power (Item 5) This link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176187&diagram_id=1364250#d1364250
Also if your dryer has a thermistor vs a thermal fuse
(Item 27) of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176187&diagram_id=1363930#d1363930
it can also shut the dryer down when it gets too hot.
You should check all of your vent ducting from inside the dryer all the way through to the exit point on the outside wall (vent flapper) for obstructions / lint.
Also if you use dryer sheets (Fabric softener) you should clean your lint filter with white vinegar then soap and water / rinse. The particulate fromthe dryer sheets cakes onto the filter. It looks clean but willnot pass enough air.
This should give you something to go on to try and resolve the shutting down issue.
Thanks for using FixYa.
Kelly
SOURCE: amana dryer NED7200TW quit heating, it appears
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
SOURCE: I have replaced the thermistor
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Amana dryer, (as you may or may not know this model is built by Samsung) and it is displaying a e5 error (actually looks like a e5 error, but it is indeed t5 but that's because of the digital display)...it is actually a "temperature sensor" error, hence the "ts".
As described in the service manual from Maytag...
"tS" Dryer Thermistor Short Sensed - The Thermistor resistance is very low.
Check for:
Clogged lint screen. (remove and wash under hot water & mild soap...a old toothbrush works well for scrubbing)
Restricted vent system.
Check Thermistor resistance...10000 ohms @ 77°F/25°C
If you've replaced the thermistor already, that leaves either poor air flow due to clogged lint screen or clogged exhaust somewhere else along the line. Here's what I would suggest you try. Remove the lint filter (clean it as mentioned above) and unfasten the vent from the back/side of the dryer, whatever the case on your machine. Run it through a cycle without a load and post back with the results.
I can send you the service manual if you think it may help you move forward,(It says Maytag, but those are Amana/Samsung as well) but you'd need to provide an email address for me to attach it to. It is a "pdf" and 9.9mb in size.
I'll watch for your reply.
Regards,
Macmarkus :)
SOURCE: I have an Amana dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
