Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The strip of metal between the refrigerator door and freezer door (side by side)is extrememly hot. Both compartments are cooling fine--just have an issue with the hot metal strip. Fully cleaned the coils, blew out dust and the problem remains.
  • lmcavondale Jun 22, 2009
    Should the fan that blows toward the water pan be moving all the time --- I took the cardboard off the back and noticed this small fan is not moving. Could this cause the heat problem?
    Sergeant:
  • 212 Answers
Could have a restriction in coils. not bad enough to effect cooling but not letting unit to cool of properly from coils
Posted on Jun 22, 2009
  • kenrick driscoll Jun 22, 2009
    you bet. that fan lets the coils and compressor cool. there is your problem. replace fan motor
Refrigerator not cooling FRS22WNC
the damper vent door between the freezer and refrigerator isn't opening to let cold air into the refrigerator compartment from the freezer side,its in the upper left corner in the refrigerator behind a grille,if its closed you wont feel cold air flowing in from the freezer sometimes you can shine a light in this area and look in the other compartment and if no light then the doors shut and this is why its not cooling the refrigerator
Sep 29, 2012 | Frigidaire FRS23H7C Side by Side...
Inside refrigerator strip between the freezer and refrigerator
The condenser fan motor at the back near the compressor is either dirty or not running at proper speeds. Clean the coils for air flow over compressor and if the fan is not running replace the fan.
Jul 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The metal between the fridge and freezer compartments is HOT
thats complete;y normal especially if it runs a lot or you open and close the door a lot in a warm and humid climate
May 31, 2010 | Sub-Zero 695/O Side by Side Refrigerator
Mod ED27DQ side by side refrigerator-Freezer works fine-refrigerator will not cool below 45 degrees
check the damper door located between the freezer and refrigerator compartment,if it is iced up it cannot open up and let cold air into refrigerator compartment from the freezer compartment,deice this part and then adjust the refrigerators cold control and see that the door opens and closes with controls adjustment
Jan 31, 2010 | Whirlpool Refrigerators
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Both Freezer door and cooling door and a metal strip were hot
That is a good thing. you want that to happen what it does is it avoids condensation to form around the doors
Apr 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Jan 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
258 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
