Question about Cuisinart Food Processors
How to remove a stem stuck on disc?
How can I remove the slicing disc from the stem? It is stuck.
4 Suggested Answers
SOURCE: Disc stem stuck
If you mean the post which the cutter thing connects to I have the same problem. I got out my jar of vaseling and smeared vaseline   in the hole after I pried the pole or disk out of the opening with a flat head screwdriver
a bit better   at least it comes out. Now if they would only make the post a tiny bit smaller at the top so the container comes off without a lot of effort,... Mine takes the post with it now that I have put the vaseline on it. good luck
Posted on Jul 22, 2008
SOURCE: Disc stem stuck...can't pull it off.
Hey I had the same problem. This may sound primitive and stupid but it worked. Give the stem a good whack with a wooden spoon all the way around, it will come off.
Posted on Dec 08, 2009
  • 1739 Answers
SOURCE: Needed: Black and Decker Power Pro II Model FP1550 Disc Stem, 10-cup container with food chute/cover. Does anyone have these two items?
Replacement parts for the Black & Decker FP1550 Food Processor may be ordered online from the following links:
http://www.partsourceplus.com/food-processors-fp1550-c-1_378_390.html
or
http://www.abtecparts.com/Black_&_Decker_food_processor_FP1510.htm
Trust this is helpful!
Posted on May 01, 2012
How do I attach the slicing blade to my cuisinart food processor
Slide the button down on the white stem. Place the blade on the stem, and turn the blade a few degrees and the button should click into place.
Jun 27, 2010 | Food Processors
My disc stem is stuck and will not come out.
Without careful use and care, there is a possibility that the disc stem can become fused with the motor shaft. If excess pressure is being applied to the slicing or shredding disc, this can cause immense friction and cause the plastic disc stem to "weld" onto the motor base itself.
I would suggest calling Kitchenaid Customer Service to see what options are available.
Their toll-free number is: 1-800-541-6390.
Jun 06, 2009 | KitchenAid KFP740 Food Processor
Apr 13, 2009 | KitchenAid KFP750 Food Processor
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Feb 01, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
How to attach grating/shredding blades to GE Food Centre FP22
When you remove the regular chopper blade, it should fit on top of the stem. The chopper blade must be removed to use the slicer / shredder attachments.
Jan 05, 2009 | GE Food Processor
I am unable to remove the disc stem
There is no mechanism to lock the stem onto the base of the KFP750. It's just held on by gravity, so you're not missing anything simple!
It's possible that the soap dust got in there and glued in on. Take a blow dryer or very hot rag (use tongs!) to the stem to see if you can soften the soap, then pull up the stem.
Dec 26, 2008 | KitchenAid KFP750 Food Processor
Disc stem stuck
Oct 20, 2007 | KitchenAid KFP740 Food Processor
Food Processors Logo
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
