Question about Solar Carlon Thyrocon Dimmer Controls Toggle 2 For 1
Thyrocon PP-1003 wireing diagram switch to fixture
I have 3 new t5 4 bulb ho high bay fixtures with an advance ICN-4S54-90C-2LS-G ballast. When I turn on the switch only the 2 outside bulbs light up on all 3 fixtures. How can I make the inside bulbs
If only two bulbs are lighting on ALL the fixtures, this usually indicates wiring.
Check wiring diagram as follows.
If unsure, contact local electrician to ensure proper wiring within your states electrical code.
http://www.stanion.com/pdf/advance4.pdf
Nov 24, 2014 | Home
Install 67888
67888 is a brass-and-black colored exterior single wall light fixture with black and white wire and bare ground wire.
If this is a new light fixture, and you are running a wire to it, copy following links to see basic wring diagrams.
http://waterheatertimer.org/How-to-wire-switches.html
Aug 02, 2012 | Hardware & Accessories
New fixture installation
Fixture is not identified.
Usually each light fixture is held in place with 2 screws -or- a center nut.
Remove old light and you can see 2 wire nuts covering black wire and white wire, and possibly another wire nut covering green wire or bare copper.
Untwist wire nuts.
Attach new light fixture wires same way as old was removed.
Make sure black wire goes to black wire on light. White to white, green to bare copper.
Copy and paste following links to see basic wire nut, and single-pole and 3-way switch wiring:
http://waterheatertimer.org/How-to-select-right-wire-nut.html
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
Jun 05, 2012 | Home
Wiring diagram for cooper 7020040024
Switch is not identified.
Copy following link to see switch wiring diagrams:
Nov 28, 2011 | Electrical Supplies
I don't have the wiring diagram for my alpine cva 1003... Where Can I get a free wiring diagram?
You can view, download and print the instruction manual with the wiring diagram in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
The installation and wiring details are givem on pages 45-53 of this manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 11, 2011 | Alpine CVA-1003 Car Video Player
I know the circuit diagram but how do you
If the power originates at the location of the light (or other item being switched) you need a 3-core cable from there to to each switch location.
If the power originates at one of the switch locations you need a 2-core cable from there to the fixture and a 3-core cable to the other switch location. (If the cable to the second switch location is routed through the junction box at the fixture then you only need 4 cores from the first switch to the junction box--three switch wires and the neutral wire for the fixture.)
In all cases described above the ground (earth) wire is separate and not included in the count.
Oct 21, 2009 | Lutron CW-2-SS Claro Two-Gang Screwless...
Need a wiring diagram to connect a photocell to LS 70 sodium fixture
please give me wiring diagram to connet photocel with auto and manual switch
Sep 26, 2009 | Cooper Wiring Devices 1301-7LTWBOX LIGHTED...
Solar Carlon Thyrocon Dimmer Controls Toggle 2 For 1 Logo
82 people viewed this question
Top Solar Electrical Supplies Experts
loft404
loft404
Level 1 Expert
obsteiner
T-Comtech Repairs
T-Comtech Repairs
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
