Question about Dayton Wire Wheels DAYTON 5PHC3 Floor Drill Press,17 In,1 Hp,120/240 5PHC3
How to adjust the front pulley height on drill press to avoid pulley rubbing bottom of housing
How do you change the speed on a value craft 12 speed drill press
Most drill press' have cover on the top when opened expose two different sized pulleys. Speed is adjusted by changing to different combinations. The speed is usually shown inside the lid on a chart with the different combinations of pulleys. Hope this helps.
Aug 23, 2017 | Speed Drills
My McGraw Edison drill press is making a screaching noise,and it sounds like it is going lock up.
make sure one of your pulleys isnt rubbing on the guard housing other wise remove belt and run motor. if that sounds ok check and see if your spindle turns freely and has no play side to side if spindle shaft turns hard most likely a bearing problem could be sleeve or ball bearings will have to deassemble and inspect also if motor screams while running with belt off the motor will need new ball bearings .
Feb 20, 2011 | Drills
I have a 17 inch Craftsman Drill Press model 152.229010. I was moving it out of storage and it fell over. The center pulley on the top that adjusts the speed came loose. Does it have a screw from the...
The pulley does fit loose so the quill or the spindle can ride up and down on it. Just has to be snug enough to grab it and spin but loose enough to move up and down. Hop this helps.
Jun 21, 2010 | Drills
Drill Presses problem
If adjustments are necessary, follow the this procedure: Spindle side-play can be minimized by adjusting the locknut located on the left side of the motor unit 1-1/2 inches behind the spindle and towards the bottom of the motor unit. While moving the feed handle up and down, tighten the lock nut until the play is minimized, but not so tight so as to restrict free movement of the spindle. The spindle should return by itself to the full up position. The drive belt tension may be adjusted by removing the top cover and then loosening the two nuts on either side of the motor pulley. Adjust the motor position and tighten the nuts so that moderate finger pressure against the belt causes it to deflect 3/16" to 1/4" (see Figure 6). Excessive belt tension may result in damage to the bearings. Note: Belt tension can also affect the generation of "noise" in the drill press. Although it does not affect drilling accuracy, it may be desirable to adjust the tension for minimum noise. The spindle has been generously oiled at the factory. You may have to periodically wipe off oil that makes its way down the spindle.
Aug 27, 2008 | Makita 6825 Factory Reconditioned Drywall...
Kirby dual sanitronic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=854322
Generic problem for all Vacuums
Kirby dual Sanitronic
Posted by shelly_vando on July 30, 2008
I need help with replacing the belt
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 30, 2008 | Vacuums
How to change kirby vacuum belt?
Greetings,
Here's a video where we show you how to replace the suction fan on a Kirby Generation vacuum cleaner (also known as the impeller blade). I hope this video helps;Chris Jones
GoVacuum.com
Jul 20, 2008 | Vacuums
REPLACING BELT KIRBY CLASSIC III
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=806061
Posted by JETALBOT on July 19, 2008
I CAN'T REPLACE THE BELT ON THE CLASSIC III (KIRBY). CAN YOU HELP ME? ELAINE
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Go Ahead. Use Us.
Jul 19, 2008 | Kirby Heritage II Vacuum
How do i put on the belt for a kirby vacuum cleaner?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=793952
How do I put on
Posted by emccall3 on Jul 17, 2008
How do I put on the belt for a Kirby vacuum cleaner?
http://kirby.com/
1-800-494-8586
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
I don't know how to change the brush. HELP Kirby legend 2 vacumm
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=767761
I don't know how to
Posted by mcwalworth on Jul 10, 2008
I don't know how to change the brush. HELP Kirby Legend II vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. To change the Kirby brushroll is to dial the belt off of the fan pulley and unlock the head to the bell housing, the head will come off. Then you turn the head over and remove the bottom plate by 2 levers the brushroll will be attached. Remove the brushroll and replace it with the new one with the screw head facing down to the carpet. Replace the bottom plate and install a new belt. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
1-800-494-8586
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
How to apply the belt on a kirby vacumn
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=759766
Posted by wccles on Jul 09, 2008
How to apply the belt on a Kirby vacuum
http://kirby.com/
1-800-494-8586
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Dayton Wire Wheels DAYTON 5PHC3 Floor Drill Press,17 In,1 Hp,120/240 5PHC3 Logo
Top Dayton Wire Wheels Drills Experts
Are you a Dayton Wire Wheels Drill Expert? Answer questions, earn points and help others
