Question about MTX Audio Tna251
Mtx tna251 amp no sound tried two different subs
I have tried two subs and still no sound? the three lights flash then stay on?
  • 631 Answers
SOURCE: mtx 1501d no sound
There are a number of things that can cause it to act as you described. Have you pulled the covers off of it yet to see if you can see any problems?
If you do, disconnect power from it and don't touch ANYTHING on the board when ANY of the 3 LEDs (2 are not visible from the outside) are lit.
Posted on Aug 19, 2008
  • 5 Answers
SOURCE: Mtx TC-6001 Amps Problem
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
Posted on Dec 29, 2008
  • 36 Answers
SOURCE: mtx 1000xd led light is flashing and the subs will not work
The light flashing usually means there is a short somewhere. Check your wires to make sure there are no slices and are touching. Also check to make sure you have your remote wire hooked up.
Posted on Sep 21, 2009
thepot
  • 188 Answers
SOURCE: Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Posted on Nov 18, 2009
SOURCE: MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Posted on Jan 23, 2010
Mtx tna251 amp has bass remote that has a light glowing but turn knob up and down and no difference like simply not working no difference in bass? Posible causes,
It is actually in the controller, if you turn the remote all the way down and press on the controller until the bass goes off, you will be able to turn the bass up and down with the remote, mine worked but stopped after a month, I tried adjusting the amp but then I noticed that if I wiggled the knob on the remote that it would work, I mashed mine until it worked again and velcroed it to my console sonibcan get it on and off easily.
Mar 03, 2015 | MTX Car Audio & Video
I bought a mtx terminator amp model no TNA251 600 watt and two subs installed. It works good for few days but now its not cranking up proper bass and sound. It always has three solid red lights everytime....
does it do this all the time when you turn it on? any sound at all?
provide more information, but my guess its that the amp is blown. replace it or sell it for parts.
Nov 11, 2013 | Car Audio & Video
MTX tna251
I have the same sub combo. The problem is the amp is underpowered for the 2 MTX 12s, get a bigger amp and you should be fine.
Nov 13, 2011 | MTX Car Audio & Video
I have 4 mtx 9500 12in subs 2 of them is on a mtx 92001 and the other is on a mtx 4001d . would it be better to run all four on the mtx 4001d. for more power and a better sound or how should i run this set...
NEVER mix different power amps. Depending on the ohms of your subs, sell one of the amps, up to you. The 4001 has more power, but either amp will do the job, the amp needs to see a 1 ohm load, so your subs have to be dual 2 ohms, or single 4 ohms to do this. If your subs are dual 4 ohms then you will have to run your amp at 2 ohms which would be have the power, or a half an ohm, (Not Recomended) and be at double the power. You may be able to do a competion sound off and just "Burp" the subs, but at a half an ohm, dont expect to listen to it to long before it goes into protect and shuts down.
Sep 06, 2011 | MTX Thunder Elite TE4001D Car Amp
What is the HLI port on the MTX tna251 amplifier?
Jul 15, 2011 | Car Audio & Video
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
Not working
disconnect the subs from the amp and check to see if the amp will turn on and stay on-check the subs to see if they are blown with a different source try a pair or a single sub that you know works fine on the amp and see if it plays-this should tell you whether your amp is fried or your subs are roasted
May 19, 2009 | MTX 4002 Car Audio Amplifier
Just got this amp, and was wondering what subs I should get with this amp
Did some research and it sounds like a wicked lil amp with clean clean sound-its hard to say what subs to tell you to run because everyone has different taste- and without knowing what your setup is going to be theres no real way to actually say-the amp is made to run 3 channels -so focusing on the sub channel only i personally say get a pair of 10s or a good 12-your not throwing a ton of power so you dont have to go balls out on the subs- i personally like MTX subs and xtant is made by MTX so that wouldnt be far from home -good luck with that
May 19, 2009 | Xtant 403A Car Audio Amplifier
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
MTX Audio Tna251 Logo
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
