Question about Garden
I have a f525 48" that breaks primary belt it flips it then breaks I replaced the double pulley on deck cause it was a little bent don't know if I should replace the bearings in the pulley cause it still breaking the belt
2 Suggested Answers
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
2004 gx335 48c mower deck primary pto belt has broken twice new double pulley on rear nothing rubbing no noise
Is the belt overly tight? My mower was doing that to, turned out the belt called for was 1" longer then the belts i was buying for it, making the belt really tight and it kept over heating from rubbing and failing. I would run it for a while then shut everything off and see if the belt is hot, also check that the bearing are not hot, could be friction somewhere causing the belt to heat up and fail.
May 04, 2017 | Garden
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman mower keeps breaking primary mower belt
Have you check the tensioners? The idler pulleys that are on the arms with springs on them. My reasoning is, if the arms are rusted, or stuck for some reason and not moving freely then the springs can't pull the belt tight. If that's the case, I could see where the belt could be slipping more than it needs to and prematurely wearing out. Just something to check. Good luck.
Jul 29, 2010 | Craftsman Garden
Lgt 2654 runs fine. But when I engage the mower it pulls the engine down alot and when I start to mow it really pulls it down and it hammers. All the pulleys and idlers are free.
Sounds like the mower belt may not be routed correctly around the pulleys or may be running on the wrong side of a belt guard. Also check under the deck to make sure there are no obstructions to the turning of the blade or bent blades....you did not state where the hammering was coming from ( engine or deck ) I can only assume that it is on the deck....so these are the things I would check. Also check the tightness of the bolt on the main pulley sheave (the pulley on the bottom of the engine that drives the belt. the bolt is in the center hole of the pulley) if it is loose it can cause misalignment of the belt and juddering of the deck. If the bolt is tight, remove the belt from the engine pulley sheave and start the engine and look to see that the crankshaft is not bent causing the pulley to wobble....worst case scenario....will require new engine...hope this helps... ;-D
Jul 03, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Blade hit the ground and bent. Now getting a growling sound from blade bearing housings and mower stalls after five minutes or so.I did replace the blades...
I have a feeling that the bearings were damaged when they hit. The new blades are ok, but the bearings are growling and I don't know what is causing the engine to shut off. I would pull the deck off, check out the bearings, replace them if needed, just wobble the blade back and forth, it shouldn't move, should be tight, Take off the belt and spin the blade by hand, and see if it growls. It could be the drive pulley bearings that went, check them out too. hope this helps.
Apr 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I change the deck belt about 6 times the mower will cut the belt and the belt slip off the track, also the tension spring keep broke 3 timas.
most likely problem something is bent on the deck or a cracked support holding one of the pulleys that the belt is traveling on, if the keep is breaking the spring might be pulling the pulley out of alignment or the bearing is heating up and burning thru the belt
Sep 24, 2009 | Garden
Mandrel chews pulley
Are you sure the spindle is not bent and also are you balancing the blades when sharpening. Other then that make sure bolts are tight on the mandrel. With the deck off and standing up spin the blades and watch center of balde to see if something is bent. Also watch pulley on the other side to see if its bent.
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
