Question about Insignia NS-RC03A-13 Remote Control 118020397
How to get the remote to go to video so i can hook up my wii alls i have is one channel for the cable but remote wont go to video and how do i get it to go to video?
How do you connect a Wii to the Insignia NS-39L240A13?
Best way is through your video port on the back of your tv with the cord that came with it. Also make sure you switch your tv to the video Channel with your remote.Once its connected to your tv and you have evrything on and you uesed yopur remote to go o the remote channel your wii is hooked up to you should be all done.
Aug 06, 2012 | Insignia "- 39"" Class / LCD / 1080p /...
What channel does my tv need to be on? and what button do i press on my dish network remote to get me to the wii screen
Usually it depends on how you connected to the TV/satellite box- for instance, I have mine set on channel AUX 1 since I have connected my Wii to the TV using the component cables (the red yellow and white cables) to the port AUX 1. If you've hooked it to the Dish box, then it would be whichever accessory you connected is the channel to select in the dish system, but on the channel that your dish is hooked up (it's situational!)
Jun 25, 2011 | Nintendo Wii Console
How do I connect my PS2 to my Alba flatscreen TV? I plugged it in and everything but I go through all the channels and AVs (HDMI, HDMI2, Ex-1 ect) but I can't seem to find the channel that the PS2 has...
select the channel that corresponds with the way you connected it if it is component video check those inputs otherwise it could be an hdmi input. if you have it hooked up and you know for sure you have checked the input that corresponds than you most likely have a bad cable try a different cable to hook it up
May 09, 2011 | Video Game Consoles & Games
RCS colortrak f20352sf: Can't view video source (Wii). I've wiggled the cables, cables are hooked up properly, Channel 91 doesn't work. In the setup menu, next to channel 91, it says clear.
I just bought the same TV second-hand and had the same problem. Solution: Use remote to change channel to 00. You can't display channel 00 using front panel - a remote is required. I have a very basic RCA universal remote, & it does the trick.
Dec 07, 2010 | RCA F20352SF TV
I need to know what channel to operate my wii on. I have a toshiba tv that is about 8 years old.
Try changing the TV inputs to VIDEO or AUX, using the remote or a button on your TV. If there is not a way to connect the Wii to the TV using the 3-cable system (Yellow, Red and White), then you might have to use a VCR or DVD player to plug the 3 cables into and then transmit the audio and video from the Wii using the regular cable line of VCR or DVD Player on TV channels 3 or 4. If your Wii has a regular TV Cable jack on the back, connect that to the jack on the back of you TV and select channel 3 or 4.
Jan 05, 2010 | Nintendo Wii Console
My wii wont turn on but my paddels work fine
If by "paddles" you mean wii remotes or wiimotes then the wii is turned on and it sounds like you may have your video cable hooked up wrong.
Mar 16, 2009 | Nintendo Wii Console
Wii remotes wont hook up
did you try syncing them up by pushing the red button on the wii and the remote
Jan 03, 2009 | Nintendo Wii Console
How do you hook up a wii to this thing?
ok u can hook it up though a dvd player if ur tv wont support it make sure ur on the right channel though
Dec 25, 2008 | EA Sports Tiger Woods PGA Tour 08 for...
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Insignia NS-RC03A-13 Remote Control 118020397 Logo
19 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
