I have dish reception and the local channels aren't being recieved well. What can I do to correct this"
  • 11,896 Answers
You can always buy a cable splitter, run dish in one side, and antenna on other side.
Otherwise you can purchase a signal booster box which will enhance the signals.
Posted on Jun 22, 2009
Dish tv support
Hi Vicki,
You may call them at
  • CALL US 1-888-615-3725 for DISH
  • You can also try this steps:
  • MISSING OVER THE AIR CHANNELS The quality of reception and number of channels available depends on the antenna's placement and the customers location. Weather conditions may interfere with channel reception. The Channel Display receiver menu option may not be set correctly.
    1. Check Over-the-Air Antenna ConfigurationCheck that the wiring between your DISH receiver and your over-the-air antenna is configured properly using Setup OTA
    2. Reset ReceiverIf the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
      Please note: It may take up to 5 minutes for the reset process to be completed.
    3. Rescan Over-the-Air Channels to ReceiverAccess "Local Channels" select "Scan Locals" then "Save".
May 08, 2014 | Televison & Video
Poor reception or unable to receive certain tv channels on sets not connected to dish or cable - what is the solution?
I would assume that your using digital converter boxes for the sets that are not hooked up to cable? Do you have digital antennas? The old analog style will work but reception will not be so good. You can find digital antennas almost any major department stores. The boxes are still available at some locations. Since the broadcasting has gone digital for regular channels,analog tvs will no longer recieve stations with out a digital converter box. I hope this helps.
Aug 26, 2011 | Televison & Video
We lost local tv from Dish on one of the local channels. We want to use the TV (model LC-46D85U) to view the local channel. How do we get the TV to view in local over the air instead of the satellite. ...
Connect air antenna to RF(coax) input of tv. Go to the menu and look for channel setup.Select antenna and auto scan. When done scanning you should have whatever stations you are able to pickup. Connect Sat reciever to one of the other input on the tv. Then go to INPUT or SOURCE on remote and select tv for local and what ever input you sat box is connected to for dish.
Mar 07, 2011 | Sharp Televison & Video
My father in law has one of these digital recievers and on channel scans it says no channals! im unfamiliar with these recievers and i was wondering if u need to register or need a special antenna or what...
where was the receiver bought from? The receiver needs to be registered before it can get channels. Also you need the help of an expert that will help you scan the channels using the right/correct frequency.
The receiver needs to be connected to a dish, subscribed (registered), and it should get channels.
Good luck.
Nov 24, 2010 | Televison & Video
My 622 DVR dual (DISH ) receiver has lost 3 local channels in a row ( SAT 61.5) . Connecticut 7385,7386,7387 - (ch 20,24,26.) Other tv's/ HD box and old 310 box converters work fine. I have unplugged,...
Hello, my name is Daniel Busa with Dish Network customer service. Whats probably causing the issue would be that either you're not getting high enough signal strength on the 61.5 satellite. Otherwise there could be an issue with the box if you swap it with another reciever in the home, and the issue follws it you'll need a new box.
Oct 19, 2010 | DISH Network ViP622 DVR DTV Receiver /...
I HAVE A SUMSUNG THAT IS HD, BUT IT'S NOT HDMI,i GET REGULAR CHANNELS, BUT WHEN I SWITH TO A HD CHANNEL, IT IS ALL SCRAMBLED? WHY?
I assume you have cable. The cable HD and digital channels are usually sent in Quadrature Amplitude Modulation (QAM). The cable companies are required to send local channels in the clear but not so for any others. Regular (basic) channels may be clear or scrambled. USA many not be but HBO will be.
So you have 1 of 2 problems: (1) your TV does not do QAM or (2) they have scrambled the channels you want to see. Questions: (1) Have tried direct Over-the-Air (OTA, ATSC) reception for your locals? (2) Can you see the HD local channels on cable? (3) Are you paying for an HD box from the cable company to have the channels decoded? If in doubt contact the cable company.
Current Samsung TVs do do QAM and OTA HD. Alternatives are Dish or Direct to get satellite with an HD receiver using HDMI or 5-cable RCA. Costs are comparable but OTA wins, hands down. -Ken
Aug 18, 2009 | Samsung Televison & Video
Bad satellite tv reception in the rain-is that normal?Good weather-good reception.
It's happened to me too, it could be a loose screw thats meant to hold the dish steady, it could also be more serious and could require a new feedhorn or another part. Leave it be for a few weeks and if it gets worse call sky, if thats your provider, or price around for a local technician.
Jul 15, 2009 | Televison & Video
I'm able to view all local channel in digital (new tv with in philip hdtv indoor antena) but after conver to diggital I lost channel 7 and 9 I scan many time but sitll no lick
What local area are you in? 7 & 9 may have moved to another channel. Every distributor of channels ie. Comcast, Directtv, Dish, Bright House, etc has channels all over the map!! with no real clear plan it seems! If you go to DTV answers.com you can get the new local lineup for your area. At this point, if you still don't have the signal, you may need to re-align your antenna for the best possible reception. If you go to Terk.com you can type in your zipcode and it will show you where the transmitting antennas are located. You may need a better antenna like a Wineguard or larger Terk to get all your channels. Hope this helps
Jun 23, 2009 | Insignia Digital-to-Analog Converter for...
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
