Question about Caitlin Cary - While You Werent Looking
Weren't what does weren't mean
    Problem Solver:
  • 6 Answers
In the context provided "werent" is the contraction of were not. "You weren't (were not) looking out for your safety."
Posted on Sep 23, 2014
I Have a Technics PR-305 Digital Piano that I have and really like. I went to play on it on October 12th. Certain notes with different chords weren`t sounding.
it can be repaired or replaced if the boards are still available
Take it to an authorized service to have it repaired and failing that some shops that repair micro wave ovens have the technical ability to repair items of this nature
may be a good radio technician or radio repair shop could also do the repair as it is basically an electronic ( wireless/radio) that is controlled by keys
Oct 14, 2015 | Music
Acadia white smoke, high temp and fan won't come on
Do you have an extended warranty ?
Usually white smoke from the exhaust means the engine is burning coolant thru a blown head gasket or intake gasket.
You should also be low on coolant in the radiator.
Apr 30, 2013 | 2008 GMC Acadia
FSE1 CODE just popped up on the stove and the latch started going back and forth and the interior light would go on and off. We weren't even using the stove or oven when this happened. What does
The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cook-top. Here is the part to order.
Dec 10, 2012 | Whirlpool GR460 Electric Kitchen Range
When I turn my computer (aspire one *acer*) on it shows up saying "Harddisk Security" -Primary Master Hitachi HTS543216L9ALock
The hard disk is locked. Since you weren't the one that activated the hdd password it means that the hdd is defective - you will have to replace it and reinstall using an external CD_ROM unit and the recovery disk that you must get from here
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
Aug 19, 2011 | Computers & Internet
I just got a used Hp laserjet 1600. I have a refubished set of toners. When I first installed the toners they printed fine other than a streak in the center. Now 30 pages later the print is so faint that...
Toners are probably low. You can remove them, shake them gently, as sometimes the toner sticks to the inside walls of the toner cart.
It sounds like either the cartridges were in storage and settled, or else they weren't full or filled all the way.
Replacement cartridges are best purchased from reputable sellers who stand by their products. You may want to contact the seller if the shaking option doesn't work out.
Aug 03, 2011 | HP Office Equipment & Supplies
I just recently bought a 2004 yamaha wr250f and when I put it in gear it wants to lunge forward I already tried replacing the oil and adjusting the clutch knobs and it helped a little but it still wants to...
When you say it wants to lunge forward do you mean the clutch doesn't disengage the transmission from the engine or that when you release th clutch, it tries to jump (i.e. clutch doesn't release smoothly)? If it's not disengaging the transmission, you may need to adjust the clutch at the engine using the screw and locknut. If it isn't releasing smoothly, the clutch plates could be either contaminated or the release plates weren't installed with even spacing.
Jun 29, 2011 | Yamaha WR 250 F Motorcycles
How do I remove a broken blade on a reciprocating saw? The blade broke off at the place where it attaches to the body. Unlocking the blade by the usual means doesn't free the small piece remaining in...
Sometimes if you take the set screw completely out and then use a flat blade small screw driver to wege open the throat you can use a dental pick to get it out. Spray it first with wd40.
Hope you weren't using those cheap blades from harbor freight - that is how I learned that trick - bought the dental picks from harbor freight.
Jun 20, 2011 | Dewalt DW303 Heavy Duty 65 Amp...
I get a qick message flash taelling me achi bios not install
ACPI maybe? That would mean that power management features like sleep and hibernate weren't loaded by whatever module was loading at the time. This would also be the case for contexts like VMs. Should happen with pre-'90s machines, but unless you get further errors or some other contextual info relating a problem, it's meaningless.
May 31, 2011 | Computers & Internet
I have had a Kenmore Outdoor Gas Smoker for several years and it's worked fine, but this year started leaving a coating of soot on the food, and the flame is mostly yellow. The User Guide suggested...
Ben, the burner holes were a good start. If you removed the burners to clean them. If not, it left a lot of debris inside the burners. Also, the Venturi valves may be clogged (Spiders love them) which would affect the air to gas ratio, Which would mean the burners weren't/aren't burning cleanly. If you didn't remove the burners, that's what you need to do, before anything else.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling.
May 28, 2011 | Kenmore Grilling
M reg 1.6 zetec escort high emissions
you say the temp gauge doesn,t work could it be possible the thermostat is stuck open which would mean the engines running cold which means the auto choke won,t knock off normally if you short the temp switch wire to ground the gauge goes straight over to hot if it does,nt then the gauge is faulty but its usually the switch as far as the high c/o it could be as stated above or some thing as simple as an air cleaner c/o should be under 2.5 these carbs weren,t the best when they came out which type is it if its the v v i would get it overhauled
Aug 27, 2008 | 1995 Ford Escort
Caitlin Cary - While You Werent Looking Logo
Top Precision Series Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Precision Series Vehicle Part and Accessory Expert? Answer questions, earn points and help others
