Question about AVG Computers & Internet
I NEED STEPS TO REMOVE AVG POWER SAVING MODE FROM HP LAPTOP
NEED POWER SAVING OFF TO RETRIEVE DATA FOR WORK. HP PAVILION LAPTOP. POWER SAVER IS CHEWING THROUGH MORE POWER NOW THAN BEFORE INSTALLED.
  • 37 Answers
Need a bit more info. What is the model number of laptop and what version is the operating system?
Posted on Jun 02, 2014
2 Suggested Answers
SOURCE: avg 8 removal problem....
hi iam sharu
The recommended procedure is a time consuming one. You must download the latest version of AVG from the website, and then run it.
1) Click on the following link and download AVG to your desktop
http://free.grisoft.com/doc/5390/us/frt/0
2) Double-click on the downloaded file to run it
3) AVG will present you with three options to choose from. Choose the Uninstall option to completely uninstall AVG
Add/Remove Components - choose if you want to add/remove some components or reinstall the entire AVG program
Repair installation - this option repairs or reinstalls missing or damaged components of AVG
Uninstall - this option removes the AVG program from your PC
4) Once the uninstall has completed, restart your computer. You can then proceed to install another antivirus or install AVG again.
Posted on Jan 10, 2009
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
Power saver mode problem.
Reset the Memory cards.
And if you have video card reset the video card as well.
and it will work fine and even if it does the same issue your memory or Video card needs to be replaced.
Oct 24, 2009 | HP Computers & Internet
I need to restore icons on desktop, tried to do so, nothing works. The screen saver has covered the entire desktop face. cannot remove it.
I am not sure that the screen saver is making problems.
Screen savers turn on after at least one minute of no activity, and turn off when you move your mouse or press a button on your keyboard.
Start your PC in 'SAFE MODE' . Are there your desktop icons?
Disable or uninstall the screen saver and and restart in 'Normal mode'.
Regards.
Mar 29, 2009 | HP Pavilion dv6000z Notebook
Is there any way to retrieve data from hard drive before sending it to the HP repair center? HP laptop recalled. No monitor. External monitor does not work either.
The only way is to remove the hard disk from your laptop. It is usually easy. Remove the cover from the back of your laptop, take the hard disk, put it in a rack, then transfer the data on another computer.
Mar 16, 2009 | HP Pavilion dv2000t Notebook
Unable to start laptop
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
Nov 28, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion ZD8000 unable to go into standy or hibernate mode
Have you looked through all of your power options under
Control Panel -> Display -> Screen Saver (TAB) -> Power (look at these settings).
Apr 18, 2008 | HP Pavilion zd8000 Notebook
Randomly Shuts Off
I think ur laptop goes to power saving mode.Right click on the desktop then choose personalize or properties if u have xp.
Then click on screen saver at the bottom click change power settings.Now if the power saver is checked then uncheck it and choose balanced in that change the timings as when it should sleep according to ur wish.
If u have any other problems please ask me..
Goodluck
Please don't forget to rate me as fixya..
Feb 06, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
47 people viewed this question
Top AVG Computers & Internet Experts
Jeff
Chris Cunningham
Chris Cunningham
Are you an AVG Computer and Internet Expert? Answer questions, earn points and help others
