Question about Sanyo DP26648 LCD TV
What wireless headphones should i use
What type of wireless headphones should be used with this tv
Can I use wireless headphones with this TV?
Depends on the type of TV and the kind of headphones you have. Do they have their own transmitter that plugs into the TV? Does the TV have wireless transmission built in? Without know the make and model of both of the items it cannot be answered.
May 16, 2015 | Televison & Video
How do i hook-up a wireless headphone set to my samsung plasma tv
use either digital audio or the 3.5 mm jack depends on type of wireless headphone system
Oct 10, 2014 | Samsung PN51F5300BFXZA 51" 1080p 600Hz...
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
What kind of adaptor do I need to use sony wireless headphones with TV
i dont think you can use a wireless headphones for a tv buy a ps3 and buy netflix and you can use it than
Sep 01, 2013 | Beyerdynamic DT 100 Professional...
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
When I plug in a headphone from the jack in the back the sound still comes out the speakers not the headpone. Element fxl-1910
Is your Headphones ok - Have you tried them on something else?
Is the plug on the headphones of the correct type and size?
If you mute the TV or turn down the volume - does this affect the headphone volume?
Also, Do you get sound out of the Headphones at the same time as the speakers?
If the above checks out to be OK - You may have a faulty Headphone socket in the TV.
Normally when you push headphones into a TV it usually pushes a piece of Metal in the head phone socket that disengages the speakers
The socket can go faulty
Jun 22, 2011 | Element Electronics FLX-1910 19 in. LCD...
How do i set up the Technika TA-709 Wireless Headphones to my tv. Have lost the manual and am not getting any sound only static on all 3 channel selections.
You should have all the necessary cables to do this with the package you bought, the wire which has a headphone style plug on each end should be plugged into the headphone jack on your tv.
If they dont work then there are two further things that could be at fault:
A: The headphone audio volume controls and the actual speaker volume controls on tvs are totally different and if the actual headphone volume is turned down then you will get an interference type noise thru your headphones as no sound is being detected by the reciever and therefore they go into kind of a standby mode. !!!!!!!!!!Try looking in your TV settings menu to make sure your headphone volume is turned up!!!!
B: being an owner of a pair of these headphones I know how audio the cable can easily turn faulty from prolonged use us. The wires can easily break inside but look fine from the outside so get a new one. Headphone jack to Headphone jack cable.
I use these along with my xbox 360 wireless earpiece (fits nicely under the headphones) and I think they're far superior to the Turtle beach headphones +++ My setup is 100% wireless which also makes it better than any turtle beach setup on the market.
Jan 07, 2010 | Audio Players & Recorders
Technical spec for plantronics C60 headset
Plantronics CS60
Type: Headphone
Acoustic Seal: Sealed/Closed/Sound Canceling
Headphone Frequency Response: Hz
Headphone Sensitivty: 14 dB/1mW dB/1mW
Wireless Technology: Infrared
Battery Time: 9 hours hours
Battery Type: Alkaline
Radio Frequency Range: 1.8GHz
Transmission Range: 100 m.
Compliant Standards: TCO '07
Jan 16, 2009 | Plantronics CS60 Professional Headset
Tuning in to TV with wireless headphones
I need more info on this. What type of tuner and receiver? Is the tuner plugged into the headphone jack on the tv? If you have a tuner for tv that tunes in channels 2,3,5,12,25,60 etc that would be an older tuner that used the older NTSC standard. Tv stations now broadcast using ATSC, channel 4,1, 4.2 etc.
Dec 25, 2017 | Jensen Radio Communications
Sanyo DP26648 LCD TV Logo
20 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
