Question about Kenmore Dishwashers
My kenmore dishwasher does not dry the dishes
  • 331 Answers
You will need to make sure that the heating element is heating. this is the black element on the bottom inside the unit. you can find the repair part and manual here www.techray.com click on the guru guy and you can use the drop down menus to get the parts you need.
Posted on Jun 22, 2009
  • 77 Answers
Don't know which model you have but if it is one with drying capability then there would be a button or switch on control panel to use this feature. If you have this option and it is selected then possibly the heater coil is no longer good or possibly switch.
SOURCE: My Dishwasher does'nt dry my dishes.
set the sanitize button and they will dry
Posted on Dec 30, 2006
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Posted on Feb 08, 2008
  • 10865 Answers
SOURCE: kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Posted on Apr 19, 2009
  • 5 Answers
SOURCE: Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Posted on Sep 18, 2009
Macmarkus
  • 2605 Answers
SOURCE: How do I get the Electrolux dishwasher to dry the dishes?
Hello, I've got a suggestion and at first it may sound like I'm pulling it out of my...left field. I'll tell you the what and then I'll explain why. Try this, take a rag or paper towel and soak it with "rinse aid" AKA, "jet dry" and apply it to the top of the tub and to a lesser degree the sides as well. I suggest this to all my customer's with new dishwasher's. Now the why...all dishwasher's require assistance to dry your dishes, some more than other's. Hence the need for an additive such as jet dry, it is simply a wetting agent which help's the water run off the dishes and as a result they dry better. So why put it on the tub ? Glad you asked. The reason is exactly the same, on older dishwasher's that have had many year's of use the tub has already built up some wetting agent on the tub just by normal and continued use, the new obviously has not. The only jet dry the new one has is the added amount in the dispenser. Over a short time of regular use the unit would start to dry better on it's own, this just speed's up the process. By adding the jet dry to the tub you create a seathing action allowing water to run off before & during the dry cycle as to not have water in the form of condensation dripping back onto the dishes when the cycle is complete, which leaves you with dry dishes as opposed to wet dishes. Make sense ? I hope so, it really work's. Hope you found this helpful. If so please rate the info you received frome jere at "fixya" today and good luck. Let me know if I can assist you further. I hope you didn't find this too difficult to read, I had to use my iphone, it's the only internet connection I have at the moment. Macmarkus :)
Posted on Jan 07, 2010
Kenmore 13899 dishwasher. Will some water remain on sides and door after using heated dry?
Normally it shouldn't! If the heating element is getting warm enough to dry your dishes then it should dry the water off all but the bottom of the dryer. Can you tell if your heating element is working - as in getting your dishes dry? If not, then you might want to do an ohm check of the heating element to make sure that it has opened.
Aug 11, 2011 | Kenmore Dishwashers
Kenmore dishwasher is leaving a soapy like residue on the dried dishes. There's not too much soap. The residue won't come off dishes. Any suggestions? Any ideas how to fix?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
=00
Jan 03, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Rough film on dishes
first clean dw use tang then prime sink and run dw after that cut back on detergant
Jun 06, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
Jan 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Dishwasher model 665.16369300 won't dry dishes
can you tell me please if all the dishes aren't drying or just the ones on the top rack. i am assuming you have selected the dry at the control panel, if so, you may have a burned out heater element in the bottom of the dishwasher or a non functioning thermostat at the heater. let me know if I can help you further.
Oct 13, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore Quiet Guard
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore elite dishwasher does not dry
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore Elite 665 16912001 Dishes not completely dry.
you can check for the elemant open. it will have to be pulled out.the connection may be bad to the heater.
Oct 30, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
237 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
