Question about Dryers
How to convert 4 prong dryer plug to 3 prong - Dryers
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
I have a 4 prong tanning bed 220v and my appliance outlet at home only accepts the 3 prong plus such as the ones you see on a dryer. How can i get this converted to a 3 prong so that i can plug it in? Or...
It is because you tanning bed requires L1 and L2 (240V) and a seperate neutral, and a ground. You need an electrician to install a proper outlet. A dryer (years ago) was installed without a neautral. However per NEC electrical code even new dryers have to have 4 wires. Do not attempt to use on 3 wires !
Oct 02, 2013 | Coleman Powermate Premium Plus 6250W...
Converting 4 prong admiral ADE7005AYW to a 3 prong
Hi pete
Go to the following webpage and you will find the answers you are looking for.
Bud
Apr 24, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
I have a Maytag dryer with a 3-prong plug. My new
The following link explains how to convert a 3-prong cord to a 4-prong:
The main difference is how the Neutral (WHITE) and Ground (GREEN or BARE) wires are installed. In a 4-wire configuration, the neutral and ground are INDEPENDENT of each other and are not connected together.
Read through the link and let me know if you have questions. I hope this helps you.
Sep 02, 2009 | Dryers
Can you tell me how to hookup the three wires of 3 prong cord to the back of dryer that came with 4 wires(4 prong)? Which one goes where? I only have 3 prong plugs at my house. Thank you.
The following link explains how to connect a power cord to your appliance:
Now keep in mind, some newer appliances REQUIRE a 4-prong plug in order to work properly. You may consider having a four-prong outlet installed to accomodate your dryer.
You can try these steps by referring to to section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, please let me know. I hope this helps you.
Jul 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
Dryers Logo
14 people viewed this question
Top Dryers Experts
