Question about Estate Washing Machines
Washer flooding! Washer flooded house twice!
  • Estate Master
  • 5,323 Answers
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
By the way my advice is free cuz God is good!
Washer flooding! - 24353674-5l44rnzs0d0ajyywclqoqvey-2-20.jpgges/24353674-5l44rnzs0d0ajyywclqoqvey-2-20.jpg" alt="24353674-5l44rnzs0d0ajyywclqoqvey-2-20.jpg" class="h_mi" />
Posted on Apr 25, 2016
catriver
  • 878 Answers
SOURCE: Flooding
La Trisha, There could be many reasons for the leak, however usually all leaks are visable. Your model is a direct drive pump and motor and I have seen a lot of these pumps go bad and leak. You will have to remove the front panel. There should be 2 clips, one on each side of the washer top. Push a putty knife in these clips and the front panel should pop out from the top. Now you will be looking right at the pump on the bottom. It is held on with 2 clips and 2 clamps, a real easy fix. When you remove the front panel, let the washer fill a little again and see if the water is pouring from the pump. You will also be able to get a look at all the other hose attachments. The part number for the pump is 3363394. Good luck..
Posted on Jun 18, 2006
  • 51 Answers
SOURCE: Washer is over flowng
Seems very likely that the water level sensor is malfunctioning, and not telling the water inlet solenoids to close when the appropriate water level is reached.
Posted on Mar 13, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
Posted on May 25, 2009
MNTECH
  • 1543 Answers
SOURCE: water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Posted on Jun 07, 2009
  • 239 Answers
SOURCE: My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Posted on Apr 23, 2010
Floods when cold
Define flooding.
  1. Black smoke out of the tail pipe?
If the fuel return line is plugged,it will flood.If the fuel pressure regulator has lost its vacuum signal ,it will flood.
If there is a large vacuum leak,the O2 will see a lean condition and cause the rich condition.gas mileage will suck,big time.
This "flooding" happens when the engine is cold? ONLY?
Be sure the air filter is not clogged and the PCV is not plugged up solid.
Also,there are a few tubes from the valve cover that vents oil vapors into the air filter housing.
During this flood mode,hold the pedal to the floor and shut the engine OFF-it should NOT keep running.(Leaky injectors)...
Do this when engine is hot and cold.
Dec 25, 2012 | 1990 Volvo 740
WM2277HW LG WASHER FE error code, but water keeps going into washer when power is off, also had to turn off water valve. How can i fix this?
you need to replace the inlet valve fe means fill error the valve is stuck open this is the most common way to flood your house with a appliance usually they get stuck shut and you cant get any water in. then every now & then one can get stuck open & if you put the machine on and go out it will flood the whole house.
Jan 12, 2011 | LG WM2688HWM TROMM SteamWasher
We have a 5 year old front load whirlpool duet washer that leaks & floods and has since we bought it. We had it replaced within a year of purchase, but it continues to leak & flood even with a new...
Due to the fact that you have had two different machines with the same problem seems to rule out a problem with the machine itself. Inspect the drain system that the machine discharges into. I have seen washers that have pumps which can overwhelm the house drain--the cure was to increase the machine's drain spout outer diameter with duct tape until it was a tight fit into the house drain. This prevented water overflowing from that point. The better cure would be to increase the drain pipe size, but that can get pretty expensive. Hope this helps!
Nov 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
May 25, 2009 | General Electric WCSR2090D Top Load Washer
My maytag neptune sometimes fills with water and floods my floor
sjhtlh
It sounds like the water valve is starting to go. i would get a tech out just to make sure.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Any reported problems with new Finish Quantum Powerball tablets
Yes there have been some issues with these stuff in dishwashers without flood protection. If you want to use them you will have to get a anti-flood attachment for your washer. So its up to you to decide..
Sep 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Water sometimes does not shut off. flooded twice. happens intermittently.
If when the machine is flooding if you turn off power to the machine and it continues to fill: replace water inlet valve. If flooding water stops filling when power is interupted: clean out the end of the water level switch tube where it connects to the outer wash tub.
Sep 17, 2008 | GE WHRE5260E Top Load Washer
Whirpool
I would say to worry about it , if its flooding your house , need to open washer front panel ,start a new wash cycle and take a look to see where the water is leaking from , sounds like a broken hose under the tub that connects to the DRAIN MOTOR PUMP , AND BETTER have it fix right away cause if its getting to the main motor it could damage it , hope it helps AJ
May 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Leaking
Flooding like that usually means a bad drain hose or bad hose connection either at the bottom of the basket or at the drain pump. Need to check both.
Apr 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
