Question about Heavy Machinery
Wen electric chainsaw chain gets loose
The chain keeps coming off the saw is there a solution or is a part missing?
  • 11,896 Answers
There is a nut on the rail that the chain runs on. You can loosen it, pry the blade out so chain is snug, than tighten it while you are prying.
Posted on Jun 22, 2009
Ake 40 18s chain keeps coming off when in use
The only time I saw this was when the saw was run with the chain too loose. The chain should be snug al the way around the bar. If it is run loose for too long the chain will develop burs on the driver links. Now the driver link will not fit in the groove on the bar so the chain is tossed off. Replace with a new chain
Aug 31, 2013 | Bosch AKE 40-19 S Electric Chainsaw
I have a remington 16 inch electric saw the chain keeps coming off when I saw a small limb
Your chainsaw bar is moving back into the housing which makes it reduce the tension on the chain. You might have a bad fitting to the housing or too much grease on it. The tension screw might be missing it's spring that keeps it from changing the setting.
Mar 14, 2011 | Garden
Do you have in stock a chain adjuster for a Wen Lumberjack electric chain saw, model number 6016?
Howdy, we are not a parts provider, but rather a problem solving and question answering service. I have located the customer service number for Wen tools so you can get your part as soon as possible.
Here you go:1-800-232-1195
Thanks for using FixYa.com
Regards, Farmerbear
Sep 07, 2010 | Electric Chainsaw Sharpener
Electric chain saw, motor smoked, stopped running. Worth fixing?
Till you get the motor and get the new motor insatlled you will have more into it then a new one...
heatman101
Aug 19, 2010 | Remington Electric Chain Saw
Chain saw oil
Use regular bar/chain oil available from home centers, hardware stores, and saw dealers. Good luck!
Jun 06, 2010 | Electric Chainsaw Sharpener
Where can I find a new chain bar adj screw for WEN 3818 gas saw?
Most older chainsaw adjustments are visible when the saw is viewed from the end of the bar back to the saw. More modern ones are near the bar nuts (side). Lou
Aug 26, 2009 | Electric Chainsaw Sharpener
Need parts for WEN model 6014 chain saw
there are none realy take the two nuts lose take a flate head tighten the chain now if you can pull the chain easy around the bar you good this will give you about a 1/8 in sage on the chain...Good luck
Aug 16, 2009 | Electric Chainsaw Sharpener
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
Heavy Machinery Logo
129 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
