Question about Toys
How to fix the real cotton candy machine if it beeps
2 Suggested Answers
  • 35 Answers
SOURCE: i need the instructions on
The instructions are can be found here:
http://www.megabrands.com/media/playbooks/5777.pdf
Posted on Mar 09, 2011
Tip
Be the cotton candy maker!
Here is how to operate a professional cotton candy machine.
First of all make sure you are renting the machine from a reputable company and that it arrives with a trained professional who knows how to operate it properly.
Also make sure that the machine is on a steady base and that no children or animals can get too close.
It is best to use a plug just for the machine instead of sharing it with other appliances.
To begin, turn on the machine's main power switch and fill the floss head with sugar.
It is very important not to fill the head above 90%.
Turn the machine's motor and then the heat switch on, putting the head dial setting on HIGH.
The sugar will start forming in about 45-60 seconds.
When the cotton candy starts pouring out you should have your cone ready. Dip it in the machine and pick the cotton candy by giving the cone a twirl that will gather the sugar around the cone.
Avoid rolling the cone around in circles as it is not the correct method to gather cotton candy.
When you are done, first of all turn off the HEAT and allow the motor to continue running at least 45 seconds, in order to get rid of the leftover sugar, and cool down the heating element.
Than disconnect the stabilizer screen and clips, rinsing them in warm water to dissolve the sugar.
You can now remove the floss pan from the main unit and rinse it off.
Children must not play with the cotton candy machine. It certainly is fun but it is not a toy.
on Dec 26, 2013 | Kitchen Appliances - Others
Cotton candy machine
Sounds like a defective switch, or wire that came off. Inspect wires connections.
I am assuming it is a home use model, then you should return it, they are not repairable.
Help fix cotton candy machine
The lighter wires from the transformer, black attaches to terminal 4, (this will have many other wires attached, and can be more than one terminal labeled #4) The red from transformer attaches to #3, it will be the only wire on a #3 terminal.
The heavier red wire most likely goes thru the back wall to the brushes, and attaches to a #4 terminal also. They have used different heat controls over the years, so this diagram may not exactly match your machine, the the terminal numbers are consistant.
May 17, 2013 | Kitchen Appliances - Others
Cotton candy maker will not power on
If you have checked to make sure it is plugged in, and outlet has power. The next thing to check is a circuit breaker in the front underneath the handle. A small white button to push.
If resetting the breaker, and it runs for a second then trips again, do not reset it again, this indicates a ground fault in the machine and it needs to be repaired by technician.
If the breaker doesn't change the operation (no power) then it should be repaired by a technician as there is no easy fix for the symptoms you have described.
Mar 21, 2013 | Gold Medal Products Gold Medal 3008SS...
Nostalgia electric hard candy cotton candy manual
I believe you are looking for the Manual for the Nostalgia Electrics PCM805 Hard & Sugar Free Cotton Candy Maker which can be found online here:
http://nostalgiaelectrics.com/manuals/PCM805.pdf
Jun 17, 2012 | Nostalgia Electrics Hard Candy/Sugar Free...
Machine makes loud noise when turned on to spin
I FACED THE SAME PROBLEM . BEST OPTION IS TO GO TO THE STORE FROM WHERE YOU GOT IT DONT TAKE THE RISK OF FIXING IT YOURSELF YOU MAY TURN UP COMPLICATING THE PROBLEM MORE
Feb 19, 2012 | Gold Medal Cotton Candy Machine
Lost and need instuctions for cotton candy machine
The Instructions and Recipes for your Nostalgia Hard & Sugar Free Cotton Candy Maker PCM805 can be found here:
http://nostalgiaelectrics.com/manuals/pcm805.pdf
Thank you for using FixYa!
Aug 14, 2011 | Nostalgia Retro Cotton Candy Machine Maker...
Open Questions:
Toys Logo
142 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
