Question about Maytag Neptune MDE6700A Electric Dryer
How to replace heater element - Maytag Neptune MDE6700A Electric Dryer
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Tip
Water Heater not producing Hot Water
Most likely the Element/elements are burned out. these are easily replaced.Disconnect power to Water Heater, drain heater from bottom drain valve, unscrew or unbolt element/s. Replace with same type. Refill heater, check for any leaks around new element/s, turm power on.
on Apr 06, 2012 | Rheem Water Heaters
Water heater has barely warm water
1) Test elements, and if elements test ok, then replace both thermostats.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) If you do not want to test elements, then replace both thermostats, and if functionality is not restored, then replace both elements.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Call plumber to do the work shown above.
Feb 16, 2013 | Water Heaters
How do I replace the heating elements in my Rheem water heater
Replace heating elements can be found at amazon, click here and take a look: Amazon com rheem heating element . I hope this was helpful... cheers
Jan 31, 2013 | Rheem 82V40-2 Fury Electric Residential...
I need to replace the lower element on my Bradford White Electric Water Heater. Where can I find the element and directions to replace it?
1) Copy following link for testing steps, and clear steps how to replace water heater element on residential water heater.
http://waterheatertimer.org/images/element-wrench-on-element.jpg
2) Your Bradford White most likely uses screw-in type element
Older models use flat flange type element.
3) Buy elements at local hardware.
Match wattage of new element to wattage that shows on label on side of tank
Jan 03, 2013 | Water Heaters
Hot water element
Make sure wires are removed from element when ohm-testing.
Watt and voltage rating of element appears on end of each element.
Volts squared divided by watts = correct ohm testing.
Two-element water heaters are rated for 240Volts, but can be wired for 120Volts.
Check that water heater is receiving power from circuit breaker box.
So if breaker is 2-pole 240Volt, then check that heater is receiving 240 V across top two screws on upper element.
Replace upper element.
Other resources.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Oct 02, 2012 | Water Heaters
We installed a brand new Reliance Electric Hot Water Heater, but no hot water, only lukewarm! Replaced top heating element and still no hot water!! Any suggestions as to what we need to do now?
If you have some hot water from dual-element water heater, then that tells us:
Water heater is 240Volt.
Upper element is working. If upper element is not working, then heater has NO hot water.
Reset button is not tripped.
Electricity and breaker to water heater are delivering 240Volts to heater.
Remaining suspects are:
1) Bad upper or lower thermostat: Solution: replace both thermostats for 28$.
2) Bad lower element: Solution test and replace element:
3) Loose wire or loose connection: Solution: open both covers and inspect for burning. Tighten all screws very tight.
4) Bad wire: Solution: Buy cheap multimeter from Home Center and do a 30 minute troubleshoot of entire water heater before replacing any parts:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
When testing for voltage, rotate multimeter dial to 240-250-277VAC
When testing elements or continuity, rotate multimeter dial to Ohms.
Jan 10, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Rheem Model # 62SV-520 and I loose hot water after about 10 minutes in the shower. I think one of the heating elements is bad, but if so, which one.
There performance depends on your demand. If you are using an energy saving shower head I would expect you to have enough hot water for easily a couple of showers. But, if your using the "power flush" type shower heads that use 3.5 gpm or more, the 40 gallon heater is not enough. Also, consider type of water your heating. Is it well water or municipal. Unsoftened well (this includes some municipal well supplies too) water causes hardness ions to cake the heater element making them less efficient. If you have the low flow shower, it is likely you have an element burt out. They can simply be replaced and picked up at any big box store for less than $20 dollars. Each element can be tested in place with a continuity tester. If your not sure how to test, but would be willing to replace the elements - replace both of them. You will have to shut off power to heater and drain tank completely before removing elements. Replace elements with same wattage or higher. Most have two 2250 watt elements for a total of 4500 watts. you can easily install two 3000 watt elements and have a quicker recovery rate and more hot water than ever.
Jan 03, 2011 | Rheem 81VP6S/430126 Water Heater
Replaced both lower and top elements and upper thermostat still no hot water. proper elec. going to unit.what could it be?
You need to take 1/2 hour to learn basics and then test water heater parts before replacing anything.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Follow the troubleshooting steps, and it will tell you exactly where the problem is.
Otherwise we can guess at 20 different things.
Water heater is 240V because you have more than 1 element.
Did you test for 240V across top two screws of upper element?
Breaker can be tripped off on one leg and 120V arrives at water heater so heater looks like it has electricity, but circuit is not complete.
The problem can be loose wire, bad 240V circuit breaker, sediment reaching lower element, bad thermostat, bad upper element, tripped ECO reset button.
Did you replace factory insulation and cover over thermostats after replacing elements?
Did you vacuum out sediment when replacing lower element?
How long ago did you replace elements? If you turned power ON before tank was completely filled with water, then you burned out the element. If upper element is burned out, the tank has no hot water, even if lower element is good.
Test the upper element:
See how a water heater works:
http://waterheatertimer.org/How-it-works.html
And finally, why so many folks write to fixya saying they replaced both elements and upper thermostat, but they never replace lower thermostat for another $6? I have been puzzled about that since lower thermostat turns on and off each time tank temperature drops and is responsible for keeping water warm during standby hours. Lower thermostat cycles more times than upper thermostat.
Add a comment if you need specific assistance with any of the testing steps.
Dec 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Replace thermostat and heater element get to hot have to reset
Your question is a bit hard to understand.
You need to replace elements and thermostats because water heater is tripping reset button.
Make sure you put factory insulation back in place after working on water heater, or the heater can overheat and trip reset button.
Here's how to replace electric water heater thermostats:
Here's how to replace water heater elements (except for Rheem bolt-in elements)
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
If heater still has problems, add a comment
Nov 18, 2010 | Water Heaters
Maytag Neptune MDE6700A Electric Dryer Logo
29 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
