Question about Boating
I need the bolt assemable for mysheridan blue streak 5mm
2 Suggested Answers
remington870
  • 48 Answers
SOURCE: air rifle will not pump up
The cylinder needs to be oiled. Its the same concept as a car jack.
Go to a gun store or a Dicks/Bass Pro/Wall mart for the oil.
Posted on Mar 31, 2009
How do I put a thread on a bolt
thread the die down 2 the bottom of orig. threads then go a turn or so back off a few turn and repeat use oil or wd40 or equiv.
Jun 04, 2012 | Cars & Trucks
HI ! I HAVE A 1997 BUICK LA SABRE, WITH A BURNED OUT BRAKE LAMP BULB. AS FAR AS I CAN SEE , YOU HAVE TO REMOVE THE WHOLE ASSEM. ACROSS THE TRUNK TO GET AT IT. I HAVE REMOVED ALL 8 NUTS HOLDING THE ASSEM....
hello! Yes there is...Install a couple nuts onto the mounting bolts...Using a block of wood tap them with a hammer to break the sealant free...There is nothing holding it other than sealant..
Guru...Saailer
Jan 14, 2011 | 1997 Buick LeSabre
How to open hilti drill te 72?
To seperate the motor housing from the gear housing you need to loosen up the two 5mm allen head bolts at the base of the handle. At the top of the handle you will see a hole. there is a 5mm allen head bolt that you will access through that hole. Back that screw all the way out. The lay the tool with the gear housing down and the motor up. Remove the 5mm bolts holding the two housings together. Tapping with a soft blow hammer you should be able to seperate the housings. Be carefull that you don't lose the lube out of the housing.
Here are instructions on removing the front end.
If yours is a metal housing here is how you disassenble the front end.First you need to put a flat bladed chisel in the chuck. Then lock the chisel in a vise. Next you put a pipe wrench on the chuck cap nut. That is the piece on the end of the chuck. Using a cheater bar turn the nut off counter clock wise. You then can remove your chisel, the cap nut, an oring and the locking sleeve with two rollers. This will expose the chuck that is held in place with 8 5mm allen screws. After that you have a large snap ring to remove before pulling out the rest of the front end assy
Sep 12, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
How to replace rear turn signal light bulb. how do you remove the rear tail light cover so as to remove the bulb on 2006 Ford Explorer XLT
I just changed my rear turn signal. Really easy. There is two 1/4 inch bolts visible when you open the tailgate. Take both of those out and gently lift the light housing out towards the outside of the vehicle. There is two small clamps on the other side of the fixture that just slide right out when you pull on it. There you go
Feb 20, 2010 | 2006 Ford Explorer
How do I change parking lights in a Jeep Grand Cherokee 2000?
open hood there are two bolts holding your headlight assem to the frame. remove bolts then pull straight out on entire assem.you may have to pull a little but they will come out .I have a 2002 that i hade to do the same thing
Jan 02, 2010 | 2000 Jeep Grand Cherokee
How do i install a headlight bulb on a jeep cherokee 2002
open hood two bolts are holding headlight assem in remove bolts then pull straight out on assem there is a ball and socket fitting behind assem that is why you have to pull some
Jan 01, 2010 | 1987 Jeep Cherokee
Blue dots and streaks
Blue streaks might have been just your video connection and problem with signaling. But, blue dots is faulty light engine, aka "optical block". The engine in this could be a defective LCD array. Very expensive, a optical block is about $850. Hope it's still under warranty. You could get a rebuilt one, possibly. Need service adjustment too. Bad problem that Sony has with these kinds of sets.
Oct 05, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a Samsung LE26. I bought a wall bracket for tvs with vesa fittings. Although the holes on the backplate are in the correct place, they holes in the back of the TV are a different diameter to any...
There is no such bolt size as 4.5mm, if you look in to an imperial size bolt instead you will find that the imperial size converts back to 4mm or 5mm (M4 or M5 and nothing in the middle).
Samsung can not advise on the correct bolt for your tv model as they do not have the specification for this, this is a factory error - no other Samsung model hase this problem.
You can use PTFE tape, wrap this around the M4 bolt to give it .5mm, PTFE tape is used by plumbers to make screw threads water tight when using compression fittings.You can buy PTFE tape from any DIY store.
I have a samsung LE model, 32", I bought a TV wall bracket from an excellent website called http://www.mountright.com , they supplied with a UMount TV bracket which came with all the correct bolts for my Samsung TV.
Sep 13, 2009 | Televison & Video
Air rifle will not pump up
Mar 31, 2009 | Dmm Benjamin Air Rifle
Hitachi rear proj TV, light blue vertical streak center screen, moves slowly
Sounds like a source problem. What happens when you play
a DVD or some other source??
Need more info? Always give Model # and age----T.
Nov 03, 2007 | Televison & Video
Boating Logo
62 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
