Question about Kitchen Ranges
Amana ARTC8600 flat top electric range has f0 code. Some of the touch functions work and some do not. Tried unplugging for 5 minutes, didn't work, tried taking apart and cleaning (isopropyl alcohol) inside of glass control panel and the ribbon cable from the film circuit-there was some moisture accumulated there that I though might cause shorting or the problem, dried it with air. Reassembled and problem is same/worse. Had the back off and there is a larger circuit board and then a smaller board with the ribbon cable to the glass front control. Which is the problem and is there a work-around?
  • 742 Answers
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Does F0 code mean changing touch pad is fix & how to do that?
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Nov 27, 2009
  • 1891 Answers
SOURCE: I'm at a loss! Recently
ok so you got a tuff one . have your found the tech sheet to help you it may be in the pots and pan drawer taped to side or in some casesthe underside.../ F O CODE IS A STUCK TOUCH PANEL / the loc may be only in the read out after installing a new colck / most of these clocks and panels have to be programed to your model / instructions come with the part . if it won't program ( it may be a bad part but your doing the right things . . ck the door inter lock and the wiring . . its very important to program the new panel .. im not sure this hepled ... also look for a open connection rather than a short . mm
Posted on Oct 23, 2010
reyjoshua07
  • 1157 Answers
SOURCE: GE Profile electric range: I'm getting an F0
Hi greengib,
The Failure code "F0" description is a stuck touchpad. Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 20, 2011
Ge profile electric range f0
You need to replace the control panel.
Jul 09, 2017 | GE Profile JS968 Electric Kitchen Range
I have an amana artc8600 and the error code it has is f1. could you tell what the code means. Also, when i try to turn the oven on no matter what setting it keeps turning off i have to try a bunch of...
HI,
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and the beep
If you see f1 and hear the beep its the ERC
If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Ovens
I'm getting a periodic beeping signal and an "FO" error message from my lower oven. What is it telling me? The oven is a dual electric. Model number 326B1230P001. Thanks. Stanley Hochman
Hi!! Failure Code Fault Code Description Solution F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Although the manual recommends to replace the touch pad, try unplugging the unit form the wall for a couple of minutes to reset it. It works most of the time.
Good Luck!! Don't forget to rate this post!!
Sep 20, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
Dacor oven code FO means keypad is in depressed mode.....and then what?
Hi john56584,
The "F0" error code description is a stock function key. Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F0 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Sep 01, 2010 | Dacor Preference RSD30 Gas Kitchen Range
The F1 code appears in the digital temperature of the oven
This is for a Whirlpool F1 code, but that code means the same on virtually all brands. Try this:
You have either a bad ERC (clock) or a bad touch pad. Here is the procedure for determining your problem.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for codes and listen for the beep.
  7. If you get a code and beep, replace the ERC.
  8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Feb 21, 2010 | Amana ACF4225AS Electric Kitchen Range
Ge range js968 f0 error code
F0 error code is a failed thermistor control. The suggested fix is to replace the ERC(electric range control). You will need to inspect the ERC, touch panel, ect for any loose connections that could be causing a short. You can also try unplugging the range for 15 minutes or so and see if the error code clears. If not the ERC may need replacement.
Jan 15, 2010 | GE Profile JS968 Electric Kitchen Range
When operating the oven I will get a beeping with the error code F-5, F-1, and F-3 should I replace this range
Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Hi; We have a Whirlpool Gold range and stove - roughly two years old. The stove works but the oven and all functions ie clock set, timer do not work at all, not even a beep or anything appears on the creen...
Try holding down the off button for 5 seconds and if this does not work the start button for 5 seconds. Unplug for 5 minutes first. Then try holding the button and then set the clock.
Aug 25, 2009 | Whirlpool GR773LXSS - Stainless Steel...
I have an F0 code that came up on my display. what does that mean?
The F0 code means loss of safety signal, you must replace the adapter board.
You could try to unplug the unit for a few minutes and then plug it in as a short term fix, but if the code reappears, then replace the adapter board
Jun 11, 2009 | Amana AER5515QA Electric Kitchen Range
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Kitchen Ranges Logo
722 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
