Question about John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
John deere 4710 pto Solenoid
How do u get the pto Solenoid off
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: John deere x320 will not syart. if one coil ground
The wiring harness under the engine shroud that feeds both coils has a diode on each of the wires that connects coils.The diodes keep each coil from grounding each other out so when one diode goes bad it will only run on the cylinder with the strongest coil.Order new harness from Deere,cost less than $30.
Posted on Dec 23, 2009
wireguy212
  • 1627 Answers
SOURCE: need the pto to work on a 6300 john deere tractor
If you have tried a new sensor and a new switch the the next step is to replace the pto solenoid valve.If that proves fruitless then the b.c.u.needs to be replaced or bypassed.The solenoid valve will cure your problem 90% of the time.If that does not work,let me know,i can tell you how to by-pass the b.c.u..
Posted on May 08, 2010
wireguy212
  • 1627 Answers
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Posted on Jun 05, 2010
I have a john deere 420 that the pto will not engage. I do have power at the switch
You are going to need to Google John Deere 420 wiring diagram. There is a 30 amp fuse in the PTO power circuit. This provides the power to the Time Delay Control Module which has the solenoid in it. Any chance you can here the slonoid click? There, is a safety interlock switch on the seat. And everything goes to a common ground lug that may be corroded or loose. If the PTO light comes on but dim, then start with the ground. Quite a lot in this circuit.
Dec 14, 2013 | Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
John Deere 4410 PTO error code. One long flash, one short flash and then six short flashes.
Check the wires on the solenoids.
http://www.tractorbynet.com/forums/attachments/john-deere-owning-operating/39426d1117768879-4410-power-take-off-stopped-665916-solenoids.jpg
Items L, M, N are mid PTO, MFWD, and rear PTO respectively
Also look at the skid plates as the possible cause of wire damage. A cheap spot / zip tie will keep the wires away from any future damage. Often the wires are damaged / torn off by a foreign object striking the Solenoid.
Thanks for choosing FixYa,
Kelly
Jun 19, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
Need the pto to work on a 6300 john deere tractor we have changed the fuses and changed the sencer on the back can you help
May 03, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Need help finding the PTO and the solenoid in a 445 John Deere Lawn Tractor. Diagrams prefered. Thank you for your help.
PTO on tis machine is located inside of trasmission,switch on dash.Solenoid/coil is located on rear of trans at the top.When energized the coil magnetically moves a valve inside of trans an allows high pressure fluid to engage clutch.In 15 years with Deere I only had too replace 2 solenoids and no clutches.
Sep 18, 2009 | Garden
John Deere 445 pto will not start Smoke from
If smoke is coming from solenoid on rear top side of trans then internal windings are bad but usually it will blow the fuse.Remove plastic nut from solenoid,slide solenoid off shaft then engage PTO.If solenoid does not smoke slide screwdriver or something like it into solenoid and see if there is any Magnetic force.If smoke comes from deck check idlers and spindles for movement.Be sure to ckeck gearcase oil level on the deck.
Aug 09, 2009 | Garden
1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Jun 09, 2009 | Diesel Garden
John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor Logo
74 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
