Question about Dremel Multi Max Kit
Dremel multi max stops when pressure is applyed
I took mine apart due to the same reason. Seems like the yoke that fits over the drive bearing is worn or bent to oversize so that it doesn't make a complete rotation. Hence, a very small or no cutting swath. You can replace the drive head for about 22 bucks plus shipping, (dremel parts) or go to Home Depot and get another one for 70 bucks plus tax. Or do as I did and go to harbor freight and get a Chicago Electric multi tool for about 30 bucks. It works fine. I'm not a professional and don't need a 200 dollar one.
Posted on Nov 26, 2016
2 Suggested Answers
  • 90 Answers
SOURCE: I have a dremel multi-max. It was a display. I
try tool parts direct, they list dremmel.
Posted on Aug 31, 2010
Stopped working
The speed control pot has become dirty from eating it's own dust. Try squirting electrical contact cleaner into the slot in front of the pot. Guard your eyes!! Rotate the pot from end to end a few times and repeat if necessary. Let it dry before applying power.
Jan 22, 2014 | Dremel Multi Max Kit
My Dremel max won't start
Check and replace brushes as necessary. Also, check that the actual electrical switch is functional. I had to add a drop of crazy glue on the tip of the interior plastic handle housing that supports/puts pressure on the electrical switch to keep it in position. The off/on thumb slider actually extends well into the housing and activates the electric switch by moving back and forth. Over time, the plastic wears and does not plunge the on off switch button. A drop of glue on the tip of the plastic post extends it & causes enough pressure to make the electric switch to function again. Brushes (filed to fit) and glue = good as new Dremel :o)
Dec 08, 2012 | Dremel Multi Max Kit
Attatching dremel blade
You can't attach this to a Dremel Stylus. This blade is specifically for the Multi-Max tool. A link is below.
http://www.dremel.com/en-us/Tools/Pages/CategoryProducts.aspx?catid=2094
Oct 21, 2012 | Dremel Multi-Max MM462- 1 3/8 inch BiMetal...
My multi max stopped running in middle of my project
call 1300 307044 aus for replacement it may be falty
Jun 03, 2012 | Dremel Multi Max Kit
Dremel MultiMax 6300 has stoped working Will not turn on.
Mine died also. It's the on off switch. Where can I get parts?
Oct 27, 2011 | Tools & Hardware - Others
Will useing an extention cord afect the dremel mutimax i had one quit on me orderd a new one and that one did same thing on the same day and the cord i am using is lager than the one on the dremel and is...
Sounds like you have a voltage prob at the wall recepticle. Use a VOM.and check the voltage at the wall at diferent recepticles as you may have loose srrews. Loose screw on the recepticle can raise the ampraga and kill your unit.....
Jan 21, 2011 | Dremel Multi Max Kit
Can I buy a new cord for my dremmel multi max? my dog chewed it up and can I order it?
If there is one ck with (ereplacementparts.com) you will need your mod. # good luck
Nov 28, 2010 | Dremel Multi Max Kit
Apr 19, 2010 | Dremel Multi Max Kit
I have a dremel multi master that suddenly quit. my first one did the same thing I did kick the **** out of the first one and got my moneys worth. the next one died suddenly , wasnt overheated and used...
they do that a lot dont they? sorry all you can do is strip it down and see if there is a fault in it that an easy fix but normaly they just go in the bin when they stop working
Mar 27, 2010 | Dremel Multi Max Kit
Dremel Multi Max Kit Logo
267 people viewed this question
Top Dremel Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Dremel Saw Expert? Answer questions, earn points and help others
