Question about Mountain Plumbing Water Heaters
Mountain Plumbing MT1100
Leak
Leaking tank
Same problem Leaking unit!... and also saw issues with the thin rubber hose.. other listed that their hose melts!!
Oct 09, 2010 | Mountain Plumbing Mountain The "Little...
My hot water from the Mountain Plumbing hot water dispenser has a lot of white pieces in it. Has the tank failed?
No attack on this scale is heating element that dissolves when it is possible to disconnect apperaat water heating and draining than doing it in vinegar and let the heat once again connect and then empty and most calcium is removed from apperaat
Nov 08, 2009 | Mountain Plumbing Mountain The "Little...
Leak from hose that connects MT641 Heating Tank to Dispenser
It may be a push n lock. If you can send a pic of your phone vam, send one and we can see what's needed. Co7196@yahoo.com. If its a push n lock, While pushing on the line push in the smaller inner sleeve and pull on the line. Make sure there is not pressure in the line.
Sep 22, 2009 | Mountain Plumbing Mountain The "Little...
Leak from hose that connects the dispenser to the tank
the temp is to high and it is just a neoprheme hose go to the hard ware store and purchast a new hose the samt size 3/8 re install it and trun the temp down on the unit, make sure the hose you get has at least 140 degree rating
Dec 26, 2008 | Mountain Plumbing Mountain The "Little...
InSinkErator Instant Hot Water Faucet leaking from heater unit model #GN1100
Make sure that there is no leaks traveling down the hoses or at the connections on the top. The tanks can leak, if you have the Stainless Steel tank the following information applies - Stainless Steel Tank: 3 years, with an extended service plan available when installed by an InSinkErator Pro Circle™ plumber. I you product is under warranty I believe that you can call the number that is printed on the tank and literature.
Dec 04, 2008 | Mountain Plumbing Mountain The "Little...
Lil gormet heating tank
anything can be rebuilt the only problem is wether the rebuild is cost effective time material wise.
Nov 29, 2008 | Mountain Plumbing Mountain The "Little...
Water Heaters Logo
37 people viewed this question
Top Mountain Plumbing Water Heaters Experts
rpar
Paul Carew
Gene Haynes
Are you a Mountain Plumbing Water Heater Expert? Answer questions, earn points and help others
