Question about Frigidaire Ovens
Why won't the oven work without the probe ?
Why do we need a probe?
  • Frigidaire Master
  • 5,323 Answers
The oven sensor is what detects the amount of heat needed to operate correctly. thus it if is not detecting any heat you may have no operation of oven
Posted on Apr 17, 2015
3 Suggested Answers
SOURCE: KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Posted on Jan 07, 2009
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Probe light on convection oven stays on. Clock won't display. Oven still works though.
    Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
    Posted on Aug 14, 2012
    Ra610 thermostat
    is easy the probe inside the oven is helt there by two clips,remove back off oven after turning off the power to it pull off knob undo nut with long nose pliers and remove change wires over one by one so they are connected right pull out old probe push new probe in though the back to the inside of oven and clip into place
    Nov 07, 2013 | Fisher and Paykel Ovens
    The probe doesn't work on my JT912 GE wall oven
    Test Continunity for your Probe, if it has good continuity, then you have a internal issue with the Oven... More than likely, you are going to need a Technician
    Apr 10, 2013 | GE Profile JT912 Electric Single Oven
    Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
    My oven won't reach the appropriate temperature
    It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
    Jan 19, 2012 | Whirlpool Ovens
    Whirlpool Range model RF386PXGQ2 broiler won't shut off
    Hi.
    If the element does not turn off, possible faults are:
    Shorted temperature probe.
    Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
    Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
    Defective control module.
    If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
    Testing must be done by a trained technician.
    Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
    I Lost the instructions for my GE profile Oven probe. Need advic
    I need oven probe instruction and oven conversion time with the convection oven for cooking a forty pound turkey.
    Nov 25, 2009 | GE Profile JT952 Electric Double Oven
    Superba convection oven probe display problem
    I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
    Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
    Aug 07, 2008 | KitchenAid Architect® KEMS378S Electric...
    Temp probe indicator stays on
    sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
    Do you still have the user's manual for this unit?
    Feb 13, 2008 | Thermador C272 Electric Double Oven
    Ovens Logo
    54 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    ashburton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
