Question about Creative Labs Zen MicroPhoto MP3 Player
Busted screen wont turn on, and charging sign wont appear when it is plugged in, although the buttons will light up :(
  • mshipley Nov 04, 2007
    was working fine, now i fully charged it and the screen wont come back on.
  • 4,402 Answers
Remove the battery and usb and reconnect them
Posted on Dec 08, 2007
Have been charging it for over 24 hrs it wont turn on?
If a little lamp is lit when you plug in the charger (indicating that the device is charging), then try holding the power button down longer until something appears on the screen. If no lamp is lighting when you plug in the charger then there is something else wrong. Check it is the right power supply for the device and that you are plugging into the correct hole of the device (not the earphone connector). It also may be the charger itself is not working.
Mar 05, 2015 | Tablets & eReaders
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
JVC MODEL AV29VT34 the main power red lights is on... when you press the power button in the remote,it wont turn on the whole system,the relay on the board is just clicking... no appearance in the...
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail. Also check for dry soldering joints on the main board . solder all suspected joints as poor connection can also trip and make the circuit inactive. Use a good observation lens and lamp .
Sep 06, 2011 | Televison & Video
There are 3 signs on my cell while charging.
firmware issue. kindly download 3.1.2 firmware and and jail break it using blackrain.
to download firmware visit for blackrain :
use itunes to update the phone to select the firmware keep pressing SHIFT button n then press restore n browse n select the firmware file.
Feb 28, 2010 | Apple iPhone Smartphone
My phone is not powering on when i plug the charger in it has a green light in the top right corner but its not turning on when i press and hold the button on the top left
try taking the battery out and while holding the power button in put the battery back in, if you still get nothing on the screen try doing the same , holding the power button down while you insert the charger.
If a tri coloured screen appears you will be able to reflash it, if it doesnt appear, then your battery is dead and it wont charge no matter how much you try, the MDA(or wizard) wont charge the battery, unless windows is running, i would recommend you buy a new battery, they are cheap enough
If the battery is very low but you can get the multicoloured bootscreen, i would not advise flashing it as you have no idea of how much charge is in the battery, if the battery fails during flashing you wont have a phone anymore
Dec 29, 2009 | T-Mobile MDA
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Aug 22, 2009 | Creative Labs Zen Digital Media Player
My ipod nano wont do anything
I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Aug 05, 2008 | Apple iPod nano
K700i Wont turn on or charge
your problem is a firmware which would mean you would have to get your firmware reset to factory sorry mate
Jan 11, 2008 | Cell Phones
Ipod nano 1st generation trouble! help!
Sounds like a corrupt hard drive.
put it into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Find it in "my computer", right click it and select format. Choose the FAT32 option and hit OK.
Once its done, restart your computer and plug in your pod. Start itunes and it should automatically reinstall the ipod firmware.
Nov 30, 2007 | Apple iPod nano
Creative Labs Zen MicroPhoto MP3 Player Logo
69 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
